I see that HS is getting into the switch business...
What kind of dimming circuit is used in these: Forward Phase, Symmetric Forward Phase (i.e. no DC created), or Reverse Phase? Hopefully it uses Reverse Phase (though I am guessing not), and if not, one can be made available, as some lights (ELV and some LEDs) must have that type.
Also, it would be nice to see a fan control switch, other than the relay on-off one. That is the reason I used Leviton, as they were the only ones making a fan speed control "dimmer" switch. There are many others that are in the same boat, and want a unified look to all switches. I would not be against changing to HS switches as a future upgrade, but only if there is a fan speed control one available.
