After a long time with very few problems. for a couple of days now I have serious problems again with these errors :
Jul-28 12:33:23 Z-Wave Error New Interface: The New Interface interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
Jul-28 12:33:07 Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.0.12...
Jul-28 12:33:06 Z-Wave Error New Interface: The New Interface interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
Jul-28 12:33:03 Z-Wave New Interface: Getting node information from controller...
Jul-28 12:33:03 Z-Wave New Interface: Z-Wave Ethernet at IP 192.168.0.12, connected to interface ok.
Jul-28 12:33:03 Z-Wave Error New Interface: Exception transmitting to IP 192.168.0.12: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
This happens every 10 minutes or so. I have a event which triggers if this error occurs 3 times, that then reboots my Z-net. I also get notified via a push notification. I usually get one once every few days, the Z-Net reboot normally cures the problem. Not this time. Even after powering down the Z-Net, and the HS3 PC, and still every 10 minutes or so I get a Z-wave error.
My Z-Net is a V2, and I am on the firmware .23 might be .24 but it was the latest when I checked a month or 2 ago
I assume because of these errors, I have trouble logging into my system remotely. It keeps saying Homeseer is not running, after trying for a few minutes I can get back in for a few minutes before the systems goes offline again. This I have not experienced before...
Jul-28 13:05:50 Info System connected to MyHS Service successfully.
Jul-28 13:05:49 Info System connected to MyHS Service, waiting for acknowledge...
Jul-28 13:05:42 Z-Wave New Interface: Getting node information from controller...
Jul-28 13:05:42 Z-Wave New Interface: Z-Wave Ethernet at IP 192.168.0.12, connected to interface ok.
Jul-28 13:05:42 Z-Wave Error New Interface: Exception transmitting to IP 192.168.0.12: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
