Z-Wave Multiple Duplicate Children for Devices
    I can't seem to understand what is causing my Z-Wave Devices to have multiple duplicate Children for a device.
    In this picture below there are duplicates for Luminance and Temperature. This Aeon Labs sensor is USB Powered.
    1 What is causing this?
    2. Can I simply delete the duplicates on the Device List Screen?
Name:	Z-Wave Multiple Children.png
    Devoir
    [ATTACH]62868[/ATTACH]
    Devoir
    This is a common problem with rescans of Aeotec devices. That is the only circumstance I have ever seen to cause the creation of " orphaned" child nodes. It is safe to delete the child with the oldest Last Date, in this case it would be the two that have not ever been updated and the two that updated on August 13.
    Then try to avoid rescanning the device unless there is a specific reason. Also try to avoid using the Full Scan in the controller menu, because it will attempt to rescan every device.
      Z-Wave Rescan
      Rpadre many thanks......
      The rescan is something I had thought would help...... I will stop using it...
      Many thanks
        Good to know. I have the same problem with a couple of Aeotec devices.
