DS10A puzzle
    DS10A puzzle
    I use a DS10A to monitor my mailbox. (It's at the end of a long driveway.) A few days ago we began to get false triggers several times each day.
    Since I limited the trigger to hours when a delivery was likely, I was curious to see if the false triggers occurred at other times as well. I added an event to record any change in the value of the HS device associated with the DS10 and discovered that it went to 'Alert' about once an hour. A more quantitative analysis revealed something more surprising:
    Yesterday it had gone to 'Alert' every hour and 4 minutes and 46 seconds with a std dev of 40 sec.
    Starting just before midnight and so far today, it's been every hour and 14 minutes and 21 seconds with a std dev of 1.6 sec!
    Needless to say, I will be replacing the DS10, but I'm curious if anyone has any idea what may be causing this.
    Here over the last 9-10 years used two DS10A's and a few palm pads connecting to two W800's (one on the main floor and attic of a two story home).
    Never had false positives on the DS10's. One was used for a Rainbird rain sensor sponge and the other was used as a laundry room window sensor.
      Low Battery?
      HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
      BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
      DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
        Originally posted by dmurphy View Post
        Low Battery?
        I've never seen that behavior with low battery, but I did check the batteries when I replaced the DS10. They were still in very good shape.
        FWIW, the new DS10 is performing normally, so it does not appear to be a problem with another component. Seems pretty clear that it was something to do with the DS10. (I'll never know, though. It's on its way to a landfill. )
          Don't they have a heartbeat to alert battery level and general connectivity?
          Maybe something changed in your HS setup where it is triggering because of the receiver side?
          --Dan
            DS10A puzzle
            I have used 25-30 DS10s over the past 5-10 years. I have seen 3-4 units that behaved erratically. When I replaced them the problems went away. I think there are many factors that affect signal strength and I think some units are better than others. I am certain that distance between the DS10 and the receiver is a critical factor. The farther apart, the less reliable.
            Maybe a different technology like z-wave would work better.
            Steve Q
              Without hijacking this thread, can the DS12A be used as readily as the DS10 or is there something significantly different about it?
                There are two differences that I can think of.
                One is that the DS12 uses AAA batteries. I find there are some applications where they appear to have less radio range than a DS10, which uses AA.
                The other is that a DS12 can monitor two contact closures independently, so registering them to the plug-in requires a bit more care to assign the codes correctly.
