Video cameras in HSTouch
    I have seen alot of posts about using cameras with HSTouch and most seem to just use an image box with a URL address and then setting "Is Video" to true, while this worked fair but slow and always seemed to bog my Homeseer server down. It also would not stop streaming as I could go to my camera server and still see the connection to homeseer streaming pics even if that page was closed on my Iphone, plus 1 to 3 frames per second was just sad. I now use a web page for each camera or groups of cameras with them on my camera server, and create a text box with the address to that server and the "Is HTML" set to true. By streaming straight from the camera server in a web page instead of routing them through the Homeseer server and then on to HSTouch my Homeseer server never sees a hit from the video and I can get some good frame rates with no lag. I have used WebcamXP and is very easy to create the web pages for each camera as the software will build each page for you (cut and paste), I now use BlueIris and really like it much better.
    If anyone is setup like this or better I would love to hear about it, there seems to be some confusion for alot of users needing video support and and number of differant ways to do it. Please chime in with some thoughts!
    John
    I've also seen this. If I close WebcamXP, HomeSeer barely uses any CPU at all. If I start it, HomeSeer uses 40-50%...
    I like WebcamXP very much as it is very stable and is perfect for integrating all my different webcams and netcams. Why do you prefer BlueIris over WebcamXP?
      I have BlueIris running with 5 IP cams, but nothing in HSTouch yet. Are you running BlueIris on the same server as HS? I know with 5 IP cams at 15-30fps, BI really uses CPU.
      HS4Pro on a Raspberry Pi4
      HSTouch Clients: 1 Android
        That's the thing with WebcamXP. In "IP Mode" it is very friendly to the CPU usage, and I have 12 cams connected...
          I'm jealous! I have a server that is running an AMD 64 X2 @3.2gHz and with 5 cams, the CPU hovers around 40%. Thats mostly because I do a lot with motion detection and it 'backs-up' frames when motion is detected so that I get a complete video.
          Are you doing motion detection with webcamxp?
            A side note; I am starting to play with VLC and it works a bit better for live streams although the mechanism of getting it to work with HS is a bit kludgy.
            Its just running the VLC EXE file from within HSTouch. Personally streaming any video has always been a bit resource intensive.
              heh - I had to upgrade the cooling fans in my Blue Iris server and I keep a close eye on the temperature
              Thats a good idea about using VLC on the HSTouch clients though. I could just grab the stream from there without grabbing it from the Blue Iris server. Hmmmmm....
                I'm only running motion detection on two cameras, so that is of course an explanation. But for WebcamXP there is a BIG difference between running it in IP Cam Mode or not.
                With 12 cams at 20 fps and two motion detecting channels, WebcamXP is using 10-12% of my four year old WHS machine (Intel Core 2 Duo 2.6 Ghz, not exactly a number cruncher).
                  BlueIris has a better web interface as seems to stream better for me. I think WebcamXp is great but I believe to other is alot easier to configure and has more options. BlueIris seems to use less CPU for me but I only use USB cameras right now, I run 10 USB HD 720P webcams but at only 840 x 448 and 7 to 15 FPS depending on the camera location. With USB2 extenders I can run a camera at 150 feet so I haven't needed anything differant yet. I run Homeseer and Squeezeserver with Squeezeplay on a small Acer Aspire Atom pc and BlueIris on a seperate 2.6 quad core machine but it rarely runs over 25-30 % cpu usage.
                  John
                    John,
                    Can you elaborate on how you do this?
                    I have found a link that will generate the code, but have been unable to copy the generated code into the designer...
                    http://www.themadhermit.net/how-to-e...your-web-page/
                    It is not is pasting correctly in HS Designer. Instead of the actual code that is created the text box field just says " <script language="JavaScript" type="text/javascript" instead of the actual code.
                      I believe you need to copy that generated code to a HTML-file, and then link to that in HSTouch.
                        I use this code to refresh images using html rather than IsVideo (much faster, much less CPU intensive, and it doesn't bog down my android phone). I have a custom piece of software that saves jpgs of each camera to a RAMdisk, at about 6 FPS.
                        <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN" "[URL]http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd[/URL]">
                        <html xmlns="[URL]http://www.w3.org/1999/xhtml[/URL]">
                        <head>
                        <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
                        <title></title>
                        <script type="text/javascript">
                        //<![CDATA[
                        window.onload = function() {
                         img = document.getElementById('refreshImage1');
                         img.src += "?";
                         setInterval("img.src=img.src.replace(/\\?[0-9]*/, '?'+Math.floor(Math.random()*9999999+1));", 500);
                         img2 = document.getElementById('refreshImage2');
                         img2.src += "?";
                         setInterval("img2.src=img2.src.replace(/\\?[0-9]*/, '?'+Math.floor(Math.random()*9999999+1));", 600);
                         img3 = document.getElementById('refreshImage3');
                         img3.src += "?";
                         setInterval("img3.src=img3.src.replace(/\\?[0-9]*/, '?'+Math.floor(Math.random()*9999999+1));", 700);
                        </script>
                        </head>
                        <STYLE TYPE="text/css">
                        BODY {margin: 0}
                        </STYLE>
                        <body bgcolor="black">
                        <img src="1datasmall.jpg" height="240" width="320"id="refreshImage1" />
                        <img src="2datasmall.jpg" height="240" width="320"id="refreshImage2" />
                        <img src="3datasmall.jpg" height="240" width="320"id="refreshImage3" />
                        </body>
                        </html>
                          Hmm... I'll try that, but I believe I had problems with that earlier.
                            can someone help me trigger cameras VLC within the HStouch
                              Are you trying to open a camera stream in VLC from HStouch?
