Can't see Panel Status on Device List
    I have two HS3 systems and both run DLDSC. In configuring the second system, I mirrored the other operating system. However, the second system will not display the panel alarm status (armed, disarmed, etc). I don't know if its relevant, but the second system panel configuration has a check by the "Status Only Device", while the 1st system does not; neither box can be changed. How can I see the Alarm Panel Status?
    HS4Pro on Windows 10
    One install with 2 Ethernet Z-nets
    2nd install with 1 Ethernet Z-net
    300 devices, 250 events, 8 scripts
    6 CT-100 tstats
    Serial IT-100 interface to DSC Panel with 8 wired zones
    18 Fortrezz water sensors & two valve controls
