hs.GetURLImageEX from remote machine..
    I think i know the answer to this. Does the hs.GetURLImageEX() method work from a remote system? As I test my plugin, it says there are no errors (it returns an empty string), but I can't find the files anywhere...Not on the local machine and not on the remote (Homeseer) machine.
    Is there a way to have this work from a remote machine?
    I even tried changing the local path to one on my local development machine to no avail. I am going to be trying this by running the plugin on the homeseer machine. I realize why it wouldn't work (the exe is running on a remote machine), but wasn't sure if HS did that on the server side or not.
    So nothing I did could make this work on a remote plugin. I think it should throw an error in that case.
    I did run my plugin locally though and it worked as expected so I'm happy that at least it works
