Give each directory a name in the directory panel
    I use your plugin to edit scripts on the Homeseer server from remote computers. Would it be possible to add a name to each directory that shows up instead of the full directory name in the view panel.
    In my particular case, I would like to define the following 2 directories in the directory panel.
    c:\Program Files\Homeseer HS3\scripts with a file mask of *.vb. It's name would be "VB scripts".
    c:\Program Files\Homeseer HS3\scripts with a file mask of *.vbs. It's name would be "VBS scripts".
    When I go to the view panel and click on the dropdown, I would see "VB Scripts" and "VBS Scripts".
    Being able to use a defined name instead of the full directory name would be a very nice feature for this very fine plugin.
    Any thoughts?
    Try out 2.0.7 in the updater
    Cheers,
    Bob
      Problem with update
      Blade,
      Thanks for the super quick update. However, there is a problem. When I attempt to update to 2.0.7 by checking the box, I get the following:
      Install/Update of package BLEditor failed.
      There is a red warning
      CRITICAL: Plugin has disconnected.
        Do this:
        1. Disable plugin
        2. Make sure the HSPI_BLEditor.exe is not running (if it is then kill it)
        3. Update the plugin
        4. Re-enable the plugin
        Cheers,
        Bob
          different problem
          I did the procedure and the installation went well.
          I get an error when adding the second directory.
          You have already selected this directory!
          I want the next directory is the same as the first, just a different file mask (and different name).
            Ah yes that will cause an issue
            I will need to make another change for that
            Will let u know when it is done - likely tomorrow
            Cheers,
            Bob
              Try 2.0.8
              Cheers,
              Bob
                Success!
                v2.0.8 works great. Thanks again for the absolutely super response and update.
