I haven't found a way to have the text display differently for triggers vs conditions. The same function is used for both Triggers and Conditions when HS gets the text.
But I do have the code doing both.
You can setup the event like you are wanting and the code will respond with a True or False when HS calls into the plugin for a condition check.
Originally posted by The Profit
View Post
