Netcam image email throwing System.OutOfMemoryException
    Hello all,
    ive been trying to get my system to send me an email of the front door cam image when the doorbell is pressed. i finally got all the bits together and it triggers but i get this error when i try to attach the image to the email.
    any ideas?
    Exception sending email via GMail (To:email@gmail.com, cc:, bcc:, Sub:door bell press at 10:19 AM Tuesday, May 10 2016, Attach:/Program Files/HomeSeer HS3/html/netcam/CurrentImage.jpg) = Exception of type 'System.OutOfMemoryException' was thrown.
    im at a complete loss.
    Raptor
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
    How exactly are you attempting to do this? What hardware are you running HS3 on? What version of HS3 are you running?
      Its an older laptop some kind of core2duo , it seems to be able to grab an older image without issue, just not the currentimage.jpg....
      i have attached the image of the event im using.
      Current Date/Time: 5/10/2016 10:58:03 AM
      HomeSeer Version: HS3 Pro Edition 3.0.0.280
      Operating System: Microsoft Windows 8 Pro with Media Center - Work Station
      System Uptime: 3 Days 22 Hours 48 Minutes 17 Seconds
      IP Address:
      Number of Devices: 616
      Number of Events: 94
      Available Threads: 200
      Enabled Plug-Ins
      2.0.25.0: BLLAN
      2.0.69.0: BLRussound
      1.0.3.0: BLShutdown
      3.0.0.22: EasyTrigger
      3.0.0.91: HSTouch Server
      3.0.0.27: MediaController
      3.0.0.11: NetCAM
      30.0.0.29: RFXCOM
      3.1.4.6: SqueezeBox
      3.0.3.3: Tasker Plugin
      3.0.1.76: Z-Wave
        This could be a case of the file is still in use when it's being attached. Try putting a delay in the event prior to attaching and see what happens.
          i tired 30 seconds and it still did it.
          ill goto a minute and see what it does.
            I have not used Netcam for Homeseer 3 yet. I installed it on my HS3 Pro running in Linux.
            It doesn't work such that I cannot test it. The help file is created in the correct directory.
            The INI file looks fine.
            Looks like it tried to write a file in the root drive using Windows nomenclature.
            This is what it wrote to the root with no images.
            HomeSeer\html\netcam\
            It should be writing to:
            HomeSeer/html/netcam/
            Has anyone used this program on the Zee-2 or HS3 in Linux?
              I tried up to 2 mins with no luck, the historic images can be added but not the current one.
              i wonder if a script that copies it might help
              Raptor
                Raptor
                How large is the file? It's saying it's out of memory, might be too large?
                Z
                  its only a few kb its a snapshot from the webcam.
                    Well that's not the problem then ...
                    So it DOES work on the historic images then?
                    Rupp might be onto something as the historic files are probably closed after they are created, but the current image file may be open. What happens if you copy the current image to another name and then run it using that new name (ie assuring the jpg file is closed)
                    Z
                      well i was wrong,
                      it was up to 187 mb, no clue how that happened. any ideas?
                      i deleted the file and it seems to be sending now.
                      thanks for your help guys.
