Still Having Issues
    Zip it and email it to me
    Cheers,
    Bob
      Here you go
        Try 2.0.7
        Please attach a new debug log zipped. Delete the old one first
        Cheers,
        Bob
          23 meg
            Wow for some reason I see your control queue filling up. No idea why. I will look at this tonight and get you another build
            Cheers,
            Bob
              #21
              Any luck?
                #22
                Try 2.0.8 in the HS3 updater.
                If you still have issues then delete the existing debug log, turn on debug logging and capture the issue again, disable debug logging attach the zipped log
                Let me know which speaker you are attempting to control as well.
                Cheers,
                Bob
                  #23
                  Master Bedroom Speaker.
                  For shits I hooked it back to HS2 and it works perfect.
                  HS3 was a clean install I did not copy and thing over.
                    #24
                    OK I will have a look
                    Cheers,
                    Bob
                      #25
                      Try 2.0.9 in the updater and let me know
                      Cheers,
                      Bob
                        #26
                        Any update?
                        How is the latest build?
                        Cheers,
                        Bob
                          #27
                          Originally posted by Blade View Post
                          Any update?
                          Bob it is still not working, I guess my last post did not save.
                          Thom
                            #28
                            Well I have no idea then because it works perfectly here.
                            Attach another debug log of you controlling one speaker.
                            It is definitely something in your setup
                            Cheers,
                            Bob
                              #29
                              Basic pc only a couple of plugins
                              Works perfect in HS2 same system Issues only with HS3
                              here you go.
                                #30
                                I see no errors in the log. I would expect to see an error if it was not controlling the speakers. I can see the commands being sent to the AB8SS and nothing looks wrong. Like I said I have absolutely no issues here controlling any speakers.
                                The com port processing has not changed from HS2. What com port device are you using (PCI or USB-serial)?
                                It has to be something on your end as no one else is reporting it.
                                Cheers,
                                Bob
