Nice! Track position % works great and so does the toggle mute. Would be nice if the track percent device could also control the track position however this is great progress and thank you for the hard work
Feature Requests: Better HStouch Experience
Originally posted by skarragallagher View PostNice! Track position % works great and so does the toggle mute. Would be nice if the track percent device could also control the track position however this is great progress and thank you for the hard work
What do you mean by control the track position? The position is updated as well and actually used to calculate the percentage. See the notes dialog in prior post to ensure it rebuilds the device status and graphic pairs.
I'll play with it some more today but when I tested it last night I was unable to skip around in a track. It did show the track position properly but when bound to a slider didn't control the track.
I did read the notes and made the change to the ini find to force the rebuild.
I'll play with it and post back
Originally posted by skarragallagher View PostNo, in hstouch it definitely won't won't control the track position. It certainly displays it but can't be used to skip around in the current track
Ah now i understand. The device is output only, so no you cannot used it control the position within the track.
So I have been using the updated plugin and all the new features are working great, love the toggle mute and the track progress bar ask work perfectly.
Would love to see the track progress bar also control the track position at some point but love the enhancements.
I did notice though (not sure if it is related to the new version) that the squeezebox triggers (like player status 'playing') aren't working anymore. I have switched my events to use the native device change triggersLast edited by skarragallagher; June 10, 2016, 10:37 PM.
Originally posted by pcp View PostCheck version 3.1.4.7 (http://board.homeseer.com/showpost.p...77&postcount=1) ; it includes several features you asked for.
I found the issue related to "the toggle shuffle action it actually does a toggle mute" and will post an updated version.
I tested all player trigger (power on, pause, new song, etc) and all are working fine. Instead of using "starts playing" try using "is playing a new song". The reason is that the first one is triggerd when LMS sends the Play event (like when you press the play button), but LMS does not send this when new songs/tracks are added and played per tests (at least with the LMS version I tested with).
