What exactly is Virtual Device On Style and Virtual Device Off Style.
Movement
So style just means CSS styles? Can it take HTML as well or change the images? If not, is there a way to change the Movement On/Off images used? I'd like to use the same two I use for the motion sensors. I suppose I could find the images you use for Movement in the file system and manually replace them there. Also, is there a way to edit the on/off style after creating the device?
