His website is here and is also linked in the first post of this thread. The installation instructions are on his website here.
Still getting iCloud 2FA auth error
Originally posted by mistermike View PostOk, here are the screenshots. I believe I did he setup correctly since the status was verified.
I'll need to do some more investigation. What model of device and OS version were those screenshots from?
Paul..
Originally posted by sooty View PostFrom the screenshots, this is not the same verification process that I've seen when testing so I expect there is something different with your setup.
Paul..
I have an AT&T Model MG582LL/A (iPhone 6) running iOS 10.0.2.
Ok, here is what I did.
1. Reset account in the device manager
2. Changed my iCloud password
3. Sent the code to my iPhone again
4. Entered the new code and saved it
I will post back if I keep getting the authentication error as shown above. Let's hope.
Thanks for your support and quick replies. This is a great plugin!
Originally posted by mistermike View PostI have an AT&T Model MG582LL/A (iPhone 6) running iOS 10.0.2.
Ok, I have had no notifications so far so good.
Originally posted by Blade View PostI just setup 2FA on my mine and my wifes iphone and it worked very well
Can the icloud update in the plugin be set for 5 minute updates instead of 10 or will that cause issues?
What is the limit before it will cause issues with Apple?
FYI:
The interval set within the root iAccount device is the default for that account. Whenever the service for that account is re-started (e.g. manual services stop / start, plug-in stop start or HS3 re-start), the interval will be reset to that default value.
Whilst the service is running for an iAccount, the interval can be overridden or paused via the controls on the "Interval" device but it will revert to the default on a re-start of the service.
Users have used HS3 events to change the refresh interval based on other HS criteria but I think by far the most used combination is to also have Geofency running on the mobile device which can then be used to change refresh intervals.
Paul..
Originally posted by sooty View PostCurrently you can set the default interval (within the iCloud account root device) as low as 1 minute and as high as 60 minutes. The only downside with small intervals is the battery drain on the devices associated with that account.
FYI:
Paul..
I can post event examples if requested.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostLeveraging GeoFency to alter the iCloud polling frequency is how I do it. 1 minute works fine and you can even create an event with a recurring trigger to do a forced update as quickly as every 10 seconds. 10 seconds is about the fastest iCloud can respond, but at that interval it will not always give you an updated location. Any more frequent polling and you are likely to ask for an update before the prior update is completed. I finally settled on 20 seconds as the fastest practical update.
FYI
The plug-in won't allow another request to be made on an account if one is already in progress.
Paul..
Originally posted by sooty View PostI hadn't considered forcing a manual poll at high frequency....
FYI
Paul..
We actually now set the interval to 1 minute on the account control and use 1 minute refreshes on the web pages. That is sufficient. We no longer speed it up with forced updates. My only point is that it will work at 10 seconds if you really want the most frequent updates possible.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Originally posted by Blade View PostI need to look more into geofency - I really do not know much about it
Is there any good info?
GeoFency just reports near/not near to predefined locations and iBeacons.
http://www.geofency.com/HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Basically the geofencing apps allow you to set up various predefined zones on the mobile device (coordinates + radius) and whenever it detects that the device has entered or exited one of those zones it sends a message to the plug-in along the lines of [DeviceId][FenceId][Entry/Exit].
As a side note:
I've just finished optimising the procedure that handles incoming fence data. It used to take about 250 ms to process an incoming fence message and return a response to the client. This is now down to about 20 ms.
As Randy has done 99% of the iCloud testing with the plug-in, he is probably much better placed to advise what works and what doesn't.
Paul..
Originally posted by rprade View PostYes, that is probably why it will sometimes not update at every 10 second interval. The response from iCloud is usually very fast, but sometimes it is slow responding. Even at 20 second intervals there may be periods when iCloud does not return an updated location. Most of the time with a 20 second interval and a web page refreshing at that frequency, you get a good idea of a device moving through traffic.
Have you changed away from using fences to change the iCloud update interval? e.g. decreasing the updates when at known places and increasing when on the move?
Perhaps I am missing the distinction between that and the discussion in this thread
Cheers
Jamescheeryfool
Cheers
James
The forced update mode I wrote about is a special thing I built for my wife that gives her a virtually real time (updated every 20 seconds) webpage she can load to see where I am. I can do the same for hers. We don't use the increased polling rate through forced updates, because once a minute is adequate. It was just an experiment.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
