After updating to version 3.0.1.177 it seems that when tripping a geofence the message panel gets the ID (long serialized number) instead of the fence name. Is this a bug, or is there something I can do to restore the previous functionality? Thanks.
Geofences listed by ID in message panel since version 177
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, LinksTags: None
Yes it is geofency._______________________________________________
Thank you [emoji3]._______________________________________________
It seems to be a little better with ~.179. Instead of the fence ID in the message panel I see the fence name, though spaces in the name have %20% instead of a space. Any chance you could take another look?Last edited by jlrichar; February 5, 2017, 04:25 PM._______________________________________________
Originally posted by sooty View PostShould be fixed in 3.0.1.80
Paul.._______________________________________________
Originally posted by jlrichar View PostI tried this version and it is still the same behavior. Only geofency devices exhibit the extra %20 in place of spaces. iCloud devices have spaces and look correct.
I don't currently have any fences with spaces in the name here but I did put some test data through and it appeared to be decoding it OK.
Let me do some real testing tomorrow and get to the bottom of it.
Paul..
There must be something I'm missing
I just tested with some simulated Geofency data with spaces in the fence name and it appears to be decoding correctly.
Could you set the "log html requests to file" option to on within the config>other page and after at least 1 Geofency message has come in, switch the log option off and email me the file.
File will be at \html\PHLocation\Logs\httplog_yyyymmdd.txt
Paul..
I just checked my Message Panel and see the same thing:
Code:#1873 2/8/2017 4:49:31 PM Fence for User: Geofency - Al with Fence Name: iBeacon%2001 changed to Not Near
Code:PHLocation http Log File. Created 2/8/2017 4:56:07 PM ======================================== DATE;REQURL;REQFROM;DATA;RESULT;TTIME 2/8/2017 4:56:07 PM;/phlgeofency;www.xxx.yyy.zzz.:64341;device=8A4ADCDD-F81F-4A5D-A2E4-5B8zzzzzzzz&major=*&longitude=-114.1&id=76DC01F4-43CF-4CEC-82B9-FC5B5D925D7F&beaconUUID=00005294-0000-0000-0000-000000000000&minor=*&date=2017-02-08T23:56:06Z&latitude=51.1&entry=1&name=iBeaconU%2003;200;0
AlHS 4.2.8.0: 2134 Devices 1252 Events
Hi Paul.
Thanks for taking a look at this with the new version. I just installed 3.0.1.82. The spaces are now spaces again in the geofency message panel. However if you enter a fence the message panel shows a not near message even though the device for the fence shows near. To put it another way if you enter or exit a fence It seems that the message panel will only show not near messages now. Let me know if you need any logs or anything. Sparkman, is it behaving the same for you? I tested using the enter and exit commands under webhook in the geofency app._______________________________________________
