Description:
Receive RF lighting, security and environmental sensor and remotes.
Software security panel.
Graphical charts for environmental sensors and electricity/gas/water usage.
Control cheap RF lamp and appliance modules and electrical curtains with the RFXCOM transmitter.
Up to 4 RF receiver interfaces and 4 RF transmitters can be connected using an USB, LAN or WLAN interface to the PC.
The USB interface is for local use only and the LAN/WLAN interfaces can be used for local and remote monitoring and control.
The LAN and WLAN interfaces can also be connected via the Internet to monitor and control remote locations.
Receive sensors with the RFXCOM RF receivers:
The plug-in processes the received RF data from a lot of wireless RF sensors and RF remotes. Those can be for example:
- X10 security sensors and remotes,
- X10 lighting sensors and remotes,
- Digimax,
- RFXSensor for temperature, humidity, barometric pressure,
- RFXPower for electricity usage metering,
- RFXMeter with RFXPwr and RFXPulse for electricity/gas/water metering,
- Visonic security sensors and keyfobs,
- Oregon Scientific sensors and body weight monitors, (see the list at the end of this page)
- KlikOn-KlikOff/DomiaLite/NEXA/BBSB/ELRO AB600 (chime, remotes, wall switches),
- HomeEasy,
- ATI Remote Wonder.
The battery status of Oregon Scientific sensors is automatically hided until a battery empty signal is received.
The plug-in has a build-in software security panel.
A status display gives the possibility to check error messages that have occurred.
The last displayed message can be used for an SMS message if an alarm occurs.
The arm/disarm status of this software alarm panel can be transmitted in RF to synchronize an X10 alarm panel
Options for security sensors:
- button to temporarily disable the sensor (if the sensor is in error or battery empty)
- delayed sensor (to enter or leave the house if the panel is armed)
- "away only" sensor (mainly used to disable motion sensors if armed-home)
- active sensor (sensor is used in the security panel)
- log sensor actions to a database
Control RF devices with the RFXCOM RF transmitter:
The plug-in can control different types of cheap RF lamp/appliance modules and electrical curtains.
The transmitter can also transmit X10 RF lighting signals but the preferred method for those signals is to use a CM11 or CTX35.
- X10 lighting,
- Arm/Disarm X10 alarm panels,
- KlikOn-KlikOff, DomiaLite, ELRO, Flamingo, NEXA, BBSB,
- HomeEasy, (with preset dim levels)
- Harrison electrical curtains.
RFXCOM receiver and transmitter documentation, Quick Start Homeseer Guide, charts documentation and plug-in documentation is available at http://www.rfxcom.com/downloads.htm
- Digimax,
- HomeEasy,
- X10 lighting,
