I have a ZRF113 attached to a relay which turns on a water heater. I had the ZRF controlled thru another zwave device which is currently not working. HS is currently turn off because the house is rented at this time. Is there any way that I can control the relay manually so that the water heater will work??
ZRF113 - Z-Wave Relay Fixture Module: Can it be controlled manually?
You should be able to use a Z-Wave remote. http://store.homeseer.com/store/HA07...ngs-P4C56.aspx
Originally posted by Rupp View PostYou should be able to use a Z-Wave remote. http://store.homeseer.com/store/HA07...ngs-P4C56.aspxHector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
