I just got a 8320 for Christmas and am having trouble getting it installed.
First, if the unit is not connected to any wiring (i.e. just taken out of box) and I pull out the little plastic battery saver tab, should the thermostat power up so you can see the temp, date, time, etc?
Mine does not. I have also tried a replacement battery. Same results. My old honeywell did power up with just the batteries. So not sure if I have a defective unit here.
The instructions say that the C common 24VAC connection is mandatory. My old Honeywell digital only required 3 connections - R (red wire color), W (black wire color), G (green wire color). When I pull the wiring out of the wall, I do have 3 other wires that are not currently used. Orange, Brown, and Blue.
I have tried connecting each of these to the C connection, but still not luck with the unit powering up.
So, I guess I am not sure if: a) I have a defective unit as it does not power up with batteries or b) the C connection is requred before the unit will power up. In which case, I am not sure how to determine if I have a C wire.
Any thoughts/suggestions?
