Can someone direct me to the path of how resize a URL weather image, to the same size of the example giving in the qv.ini. I tried applying 300 x 400 to the URL but it doesn't work.
Web page builder for Homeseer 3 & Homeseer 4
Heres the line Jon and Thks.
Column1Section2-1Middle=[image,http://radblast-mi.wunderground.com/...e=1.000&noclu]Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Hector,
Rather than:
PHP Code:Column1Section2-1Middle=[image,http://radblast-mi.wunderground.com/cgi-bin/radar/WUNIDS_map?station=TPA&brand=wui&num=12&delay=15&type=TR0&frame=0&scale=1.000&noclu,{300x400}]
PHP Code:Column1Section2-1Middle=[image,http://radblast-mi.wunderground.com/cgi-bin/radar/WUNIDS_map?station=TPA&brand=wui&num=12&delay=15&type=TR0&frame=0&scale=1.000&noclu,400,300]
Jon
When adding a URL to the page do use:
Embed
Embedrefresh
In your example your using image. If you use image will the image of the radar weather (in the example) be updated?Hector
Win.2003 OS, HS3
It depends...
If you set the entire page to refresh every XX minutes (see the PageRefreshTime setting in the docs) then yes.
If not, you can use the EmbedRefresh tag which will only refresh that part of the page.
You can use:
PHP Code:[embedrefresh,300000,http://radblast-mi.wunderground.com/cgi-bin/radar/WUNIDS_map?station=TPA&brand=wui&num=12&delay=15&type=TR0&frame=0&scale=1.000&noclu,400,300,0,0]
Originally posted by jon00 View PostI don't believe you can do so in Safari but Google Chrome has Full screen support.Hector
Win.2003 OS, HS3
Originally posted by ESSCHENK View PostHello Jon,
Is it possible to add a text after the value of a device
this is my line.
Opgewekte Stroom 1.239 17-8-2014 16:25:18
And i want (if possible)
Opgewekte Stroom 1.239 Kwh 17-8-2014 16:25:18
Thanks Ed
