Does not pair with iTunes (passcode incorrect)
    Does not pair with iTunes v12.3.2.35
    No matter what I type in for a passcode I get the following error in iTunes (no errors at all in Homeseer logs)...
    The passcode you entered was incorrect
    I've tried restarting the plugin and still no luck.
    this is likely to be a firewall problem, disable your firewall on the HS3 machine then restart the plugin and retry
      Right you are! That was an easy fix. Any idea what program I need to allow to make this work with firewall on? Homeseer? or the plugin somehow?
      BTW, Thanks a ton for the super fast reply. I've posted to about 3 other plugins and after 5+ days have still yet to receive any response. :P
        you're welcome
        the program to allow is HSPI_ITUNES_DAAP.exe, but once the plugin is paired I'm not sure it is even necessary.
