If you want to look at the structure of the v2, let me know and I can try to figure out how to get you an image.
Bob
homeseer@Z-Net:~ $ cd /tmp homeseer@Z-Net:/tmp $ tar xzf znetdown_patch-r3.tgz homeseer@Z-Net:/tmp $ sudo ./install.sh awk: cannot open /etc/init.d/ser2net (No such file or directory) homeseer@Z-Net:/tmp $
# znetdown patch modification - enable ser2net control port CONTROLPORT=127.0.0.1,1999 /usr/local/sbin/ser2net ${CONTROLPORT:+-p} $CONTROLPORT -c /etc/ser2net.conf -n& 2>&1 >/dev/null exit 0
IFDOWN=eth0 IP=192.168.1.113 CONTROLPORT=127.0.0.1,1999 RAWPORT=2001 DOWNPORT=2001 disconnect 2001 RAWPORT=2002 DOWNPORT=
[....] eth0: ifplugd process for device eth0 running as pid 1341. [info] all: device all is either not present or not functional.
