Hi all,
So I motorized three sets of roller blinds I had. I used the cheap amazon kits which are $50 each and modified them to fit my blinds. I can help people out with this process if they PM me.
The blinds are controlled by RF remotes which can be individually controlled via the three different remotes. I am in the process of soldering wires to the remotes to control them via a relay controller on a raspberry pi, which in turn will then be controlled with Homeseer. the remotes only have Up, Down, Stop.
Can anyone think of a way I can somehow use Homeseer to use a slider to control the blinds? The Up/Down only require one click and it will go all the way up or down to set limits on the motor which I programmed already. My plan for setting 1/4 way or 1/2 way would be to time the blinds and then set timers up with Homeseer.
Does anyone have better ideas of how I could do this?
