Oregon Scientific Sensors for RFXCOM?
    Originally posted by afmiller View Post
    i'd be interested in thwr800 for the pool.
    +1
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      I see a post that says the WMR100 sensors are compatible, but it looks like that system does not have a inside temp sensor that can be read, I assume that the sensor is in the base unit.
      There is a WMR80A weather station with a THGR800 remote sensor (3 channels). The compatibility list shows a THGR810 (10 channels), but is the THGR800 compatible?
        up to now all Oregon protocol 1.0, 2.1 and 3 sensors can be received.
        The list of tested sensors is here: http://www.rfxcom.com/oregon.htm
        It is possible that a sensor is received but not recognized by the RFXCOM plug-in.
        In that case make a recording of the data using the RFreceiver program, copy the received data and send this in an email to rfxcom support
          Ah, yes it is. But you you will have more than one sensor indoors, won't you?
          It's not a practical problem.
            i am using:
            9x Oregon-THN132N
            and i like em, would be intersted in some of the cheaper more advanced sensors tho.
            Raptor
            HS3 Pro on Windows 8 64bit
            53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
            Check out my electronics blog here:
            https://www.facebook.com/RaptorsIrrationalInventions
              #21
              Just noticed this thread.
              I'd be interested in THWR800 for the pool.
              +1
              Definately interested in more THGR810's as well
              Love to buy OS stuff from homeseer store.
              any update on when this may be available Mark?
                #22
                Oregon Scientific Sensors Now Available at HomeSeer!
                They're starting to trickle in now and we're expecting more this week:
                http://store.homeseer.com/store/Oreg...ific-C237.aspx
                  #23
                  Mark,
                  I vote for
                  <table border="0" cellpadding="0" cellspacing="0" width="319"><tbody><tr style="HEIGHT: 26.25pt; mso-yfti-irow: 48" height="35"><td style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; WIDTH: 143pt; HEIGHT: 26.25pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0in" class="xl71" height="35" width="191">Oregon-BWR102</td><td style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: windowtext 1pt solid" class="xl72" width="64">WEIGHT1</td><td style="BORDER-BOTTOM: black 1pt solid; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 1pt solid" class="xl73" rowspan="2" width="64">Body Weight Monitor</td></tr><tr style="HEIGHT: 26.25pt; mso-yfti-irow: 49; mso-yfti-lastrow: yes" height="35"><td style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0in; BACKGROUND-COLOR: transparent; WIDTH: 143pt; HEIGHT: 26.25pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0in" class="xl71" height="35" width="191">Oregon-GR101</td><td style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 48pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: windowtext 1pt solid" class="xl72" width="64">WEIGHT2</td></tr></tbody></table>
                  I would love these. I can't find them anywhere.
                    #24
                    Thwr800?
                    Is THWR800 Oregon water sensor currently supported? It seemed from the original post that it should be available as TEMP3 device, but I don't see it as an option in the latest plugin version 1.1.3226.27426.
                      #25
                      Originally posted by dinkme View Post
                      Mark,
                      I vote for
                      I think they've stopped making them.
                      Yes, it should work.
                        #26
                        @picta
                        The THWR800 is supported by the RFXCOM plug-in and the latest version is 15.0.0.07.
                        here is the list of sensors supported by the RFXtrx433 and RFXrec433 http://www.rfxcom.com/oregon.htm
                          #27
                          Thank you, I was looking at ACRF-2 plugin. I have installed RFXcom plugin and can see the water sensor, but how do I change the units to Fahrenheit? All other temp sensors that were registered with ACRF plugin now also display in Celsius. Do I need to change the calibration fields? Thank you
                            #28
                              #29
                              Originally posted by b_weijenberg View Post
                              Calibration value is only to correct the displayed value of the sensor if the indicated value is not the real value
                              See also the RFXCOM User Guide.pdf in the Homeseer Docs\RFXCOM directory
                              Does calibration value only provide an offset? Can it be used to set a scaling factor in addition to an offset?
                                #30
                                Calibration is used for a positive or negative offset.
                                For a scaling factor you have to use Divide by.
