Russound CAA66 questions
    #46
    RU bridge
    Sent from my XT1585 using Tapatalk
      #47
      Or is it the MY:RO
      Darn spell check
        #48
        Take a look at this how to. This is what I used to create the squeezebox player that is connected to the Russound unit.
        http://www.gerrelt.nl/RaspberryPi/wo...r-on-raspbian/
        You will also need to setup the squeezebox server, I have it running on my HS server as well.
        There is lots of way to do what you want, this is just how I did it. You have 6 sources for the CAM6.6, you will see the audio inputs on the back. The serial port is used to connect it to the HomeSeer server for control, it has nothing to do with passing audio. Mine is directly connected to the serial port on my HS server. You will have to do some searching on the net to see what usb to serial converter will work as I tried one and it didn't work and found out there are only a few out there that do work with the unit. You can also purchase or make a serial to Ethernet adapter to control over your network.
        First thing I would do is get the unit completely installed in your house, including keypads and speakers. You can test it by using a Y cable and connecting your phone or MP3 to one of the sources to confirm all is working. Then move to getting control working from HS to the russound unit. Once you have that done, you will be ready to start setting up audio sources.
        I don't have any experience with the XM tuner or the DSM media player that Russound has for other sources. I bought one off eBay really cheap about a year ago that was broken and I never got around to looking at what would be needed to fix it. I don't know if those can be controlled thru the Russound plugin or not.
          #49
          Cool tips thanks
          I picked up a cam6.6 and looking forward to settings g it up
          Also have a Insteon plm coming
          I would love to get so.e of my Lowe's IRIS devices to work too I think they are ZWave so we will see
          Merry Christmas all
            #50
            I hqve a few bluetooth receivers hidden in my house as sources for my Russound system. They have NFC tags in them which I cloned to other tags that I stuck on the Russound keypads so all you need to do to connect your phone is touch it to any keypad. The receivers are in the floor/ceiling. Too cool.
            Originally posted by rprade
              #51
              Here run Squeezebox server on my MythTV box. Runs fine today for me. Just looked and updated it. Very easy.
              An updated version of Logitech Media Server is available and ready to install.
              On some Linux distributions we provide an automatic download of Logitech Media Server update installers. These currently are available for .rpm and .deb based systems.
              Your Logitech Media Server has downloaded the latest installer to the following location:
              /var/lib/squeezeboxserver/cache/updates/logitechmediaserver_7.9.0~1482423225_amd64.deb
              Please execute the following steps to bring your Logitech Media Server installation up to date:
              Log in to your server machine using your username and password.
              Run the following command to execute the installer
              sudo dpkg -i /var/lib/squeezeboxserver/cache/updates/logitechmediaserver_7.9.0~1482423225_amd64.deb
              Here is a nice looking RPi based squeezelite streaming client.
              Squeezelite Streaming Client with Raspberry Pi
                #52
                What Bluetooth receivers did you use? That sounds cool
                Cheers,
                Bob
                  #53
                  Will this bluetooth audio adapter work with the Russound?
                  http://www.bestbuy.ca/en-CA/product/.../10291332.aspx
                  Cheers,
                  Bob
                    #54
                    Absolutely. You'll need a pair of RCA cables to hook it up.
                    I think this is the one I am using: https://www.amazon.com/HomeSpot-NFC-.../dp/B009OBCAW2
                    I have one for my daughter (NFC tag for that receiver is only on the keypad in her room) and one for the whole house with cloned tags all over. I still have one source left on my amp and am going to, eventually, run conduit for one to my back yard in my shed.
                      #55
                      What kinda range are you getting on them? I really like this idea
                        #56
                        So, I have a ranch. I finished the basement when I got it (15K doubled the Sq. Ft. of my home!) and I slipped one between the floors in a central location. The range is anywhere in the 2,200 Sq, Ft. house.
                        Normally though I play my music from my PC but the BT integration is stupendous for guests.
                          #57
                          I think you should do a write up on this
                            #58
                            Which part?
                              #59
                              Which part?
                              For me, just how you have it set up on the russound and the NFC tags. Sounds like you have 2 BT receivers (one whole house, one specific to a room).
                                #60
                                Very cool
                                I got my russound cam6.6 working g today
                                Having BT as as source should be cool
                                How long of a RCA cable to the main russound unit or RCA input on a keypad?
