Currently I'm working on a Z-Wave controlled garden irrigation system. I'd like to have it a s clean as possible and the easy integration with Homeseer. Even I don't have easy access to ethernet in my garden and wifi isn't stable. Multiple Z-Wave sensors are working fine on that distance, so that should not have a problem, and the 230V powered Fibaro act as a repeater too.
For Homeseer integration I'm using the Fibaro FGS-222, which can handle 2x 1.5 kW power switches at the same time and control external switches on 230VAC.
Click
I bought 2 magnet valves, with 2x 230VAC relais.
Click
The test setup is now quit easy, I can easily switch in Homeseer both valves:
Click
Zone control in Homeseer: Click
Now I'm ready to install all the pipelines and sprinklers in my garden.
Click
Click
Click
