what I am trying to create is a relay that can be controlled at the same time by either HS or a push button connected to one of the input pin.
However I want the status in HS to be updated whenever the relay is manually triggered by the push button.
Basically I want a light switch controllable by both sides, like the Zwave Aeon switch.
The problem I see here is that with the pin being either output or input, this is not really straightforward.
Currently I can trigger the relay from HS and manually, however the two things are not synched and there's no status update.
One way to solve this could be using Events and when the manual trigger happens, an event will change the status of the Output pin.
but I have some issues here, first for some reason EasyTrigger doesn't recognise the status change of an input pin and secondly, I want to have several of this devices and creating events for each of them is a pain.
Does anyone see an easier solution?
