So I replaced my USB PLM with the new Hub 2245-222, all the other switches and dimmers were reprogrammed by the plug-in. except this I/O linc which I use for garage control / status.
at first it failed at reprogramming by the plug-in, only the status part (input relay) would sometimes respond. but the output relay never worked.
then I went ahead and did a factory reset, manually link to HS3 again. after several tries it finally paired.
I'm getting very poor comm reliability, only 33% (174 failed out of 258 cmds). this is a fresh counter of only 2 days after I installed the Hub, i reset the comm counters.
most commands would fail, status report (input relay) also fails to report most of the time.
It used to work perfectly without any issues.
There's a dual band dimmer about 6 ft away from the I/O linc.
I also have a "plug-in switch" that is also powerline comm only like the I/O, it's also in the garage. this one never failed.
I have 30+ devices throughout the house, so I think both pairs of the power line would be covered pretty much. and I don't have any issue with any other devices.
Anyone has any idea?
