ZEE and CM11A
    ZEE and CM11A
    Tested the Zee today with a CM11A connected via a USB to serial device. Works fine. Validated its functions turning on A1 and turning off A1.
    Oct-29 8:22:01 AM Error Exception deserializing a saved status page data item from the database - it will NOT be loaded! Item: ContainerID=, User=
    Oct-29 8:21:31 AM Device Control Device: X10 x10 A1 to Off (-1) by/from: CAPI Control Handler
    Oct-29 8:21:27 AM Device Control Device: X10 x10 A1 to On (101) by/from: CAPI Control Handler
    Oct-29 8:14:47 AM Warning File does not exist: /usr/local/HomeSeer/html/custom.css
    Oct-29 8:14:47 AM Warning File does not exist: /usr/local/HomeSeer/html/style.css
    Oct-29 8:10:49 AM Error Exception in local_add: Object reference not set to an instance of an object
    Oct-29 8:08:58 AM Plug-In Finished initializing plug-in X10
    Oct-29 8:08:57 AM Info Initializing CM11A/12U on COM port /dev/ttyUSB0
    Oct-29 8:08:57 AM Warning Cannot find requested INI file: /usr/local/HomeSeer/Config/0
    Oct-29 8:08:29 AM Startup Start up complete.
    Rebooting though to see if the above log errors go away. I have updated the Zee to most current version of HS3; IE: V.38?
    Wondering now if the update didn't work as planned; something is amiss in homeseerlandia on the Zee.
    Only error seen on reboot is:
    Oct-29 8:28:58 AM Info Initializing CM11A/12U on COM port /dev/ttyUSB0
    Oct-29 8:28:58 AM Warning Cannot find requested INI file: /usr/local/HomeSeer/Config/0
    Oct-29 8:28:58 AM Startup Initializing Plug-Ins
    Geez where the heck would a zero ini file come from anyways? There is none there; wonder if it was meant to be there?
    Auto mator
    That should have been corrected already.
    Make sure you're running the latest version.
    We are at 3.0.0.17 right now.
    Wade
    "I know nothing... nothing!"
      I see the 3.0.0.14 x10 plugin version is running. How do I update the plugin?
      Do you have a link to the updated x10 plugin files?
      Should I update it on the wintel running HS3 box and copy over the exe or dll to the linux box?
      Looked and I have HSPI_X10.exe running on the wintel HS3 box and HSPI_X10.DLL running on the Linux HS3 Zee box.
      Auto mator
        I checked with Rich and he will be putting out a new HS3 version today for the Hometroller Zee with the updated X10 plugin.
        Wade
          Thank-you Wade.
          Auto mator
            Zee V.39 working along with X10 Plugin 3.0.0.17.
            Zee Z-Wave Aeon stick plugin V.3.0.0.24 is broken; disabled it for now.
            Auto mator
