Hi, I just purchased a Rain8net controller that I will be installing soon, but I have a question, is there a connection for a rain sensor? I don't see one on the unit, do you need one? If so where would you connect it to?
Rain sensor to Rain8net pro2?
Hector,
I think model Rain8netPro2 41014 has the rain sensor option connector. Model 41012 does not.
I use my Davis weather station as a rain sensor. It is not directly connected but works via the software. There is also the Digital rain guage which works well as a rain sensor.- Pete
I use my Davis weather station as a rain sensor. It is not directly connected but works via the software. There is also the Digital rain guage which works well as a rain sensor.Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
I use one RG11 as a rain sensor and it works just fine. I never utilized the feature on the Rain8Nets; with a preference to an external rain sensor externally connected.- Pete
Originally posted by Pete View PostI use one RG11 as a rain sensor and it works just fine. I never utilized the feature on the Rain8Nets; with a preference to an external rain sensor externally connected.Hector
Win.2003 OS, HS3
Its in "test" mode still. There are two RG-11's set up. Each one is connected to a counter (2) of a two counter 1-wire counter right now. I do also have a Dallas 1-wire tipping bucket and using the tipping bucket from the Davis weather station.
As its really sensitive to any rain. It will be a rain only device and not utilized in "tipping bucket mode" as the numbers were not even close to my real rain tipping bucket. Note this is me and my testing and my opinion based on my testing of the RG-11
In other words the RG-11 works really well to tell you that its raining but really bad to tell you how much its raining.
You can connect the switch though to say a DS10A to tell you that its raining outside but you still need to provide the power voltage to the device. I am using a 22/4 wire to it. Two wires carry power to it and two wires carry the switch stuff.- Pete
mcsSprinklers- Pete
Win.2003 OS, HS3
mcsSprinklers uses weather and external hardware (optional) to calculate Evapotranspiration (ET).
http://en.wikipedia.org/wiki/Evapotranspiration
Most of the other software available just creates timed sequences or calendar events to sprinkle your lawn that I know of.- Pete
Originally posted by Pete View PostmcsSprinklers uses weather and external hardware (optional) to calculate Evapotranspiration (ET).
Most of the other software available just creates timed sequences or calendar events to sprinkle your lawn that I know of.Hector
Win.2003 OS, HS3
You can get the weather from multiple services on the internet.
I use my weather station and WUN and NOAA for mcsSprinklers.
Last summer we had a drought and I was able to keep the grass pretty green watering sparingly using the automation in mcsSprinklers.- Pete
Originally posted by Pete View PostYou can get the weather from multiple services on the internet.
Last summer we had a drought and I was able to keep the grass pretty green watering sparingly using the automation in mcsSprinklers.Hector
Win.2003 OS, HS3
Yes which was a plus for me last summer with the drought we had; the grass remained green.
You also put in all of the restrictions that may be in effect relating to watering days and times; IE: odd or even addresses and morning and evening times. The application shows the % of the lawn moisture based on ET. You can see it go to 100% after a watering and watch it go down % points afterwards; depending on the weather and so forth.
The application will look at the restrictions and ET decide when to water. That said I do have a water meter but set the period of time for watering; personally here have it set to 30 minutes. That will vary though and kind of depends on your location.
You can get very granular with it; such that you can literally water by the gallons of water utilized with it versus time et al type stuff. Here it helps because our water used to be very reasonably priced 10 years ago and today its like 400% higher.
I have mine in "off" mode right now. I've attached some status screens.Last edited by Pete; April 13, 2013, 04:43 PM.- Pete
