Hi all... as followup to my previous thread a week ago... I decided to purchase the Zee... got it mostly setup last night, but I am having trouble with the MimoLite module.
I was able to import it and its six associated devices into HS3:
Andy
FortrezZ Switch Binary Node 5 Root
FortrezZ Meter Pulse Node 5 Child
FortrezZ Notification Node 5 Child
FortrezZ Sensor Binary Node 5 Child
FortrezZ General Purpose Node 5 Child
FortrezZ Switch Binary Node 5 Child
Through the HS3 controller I am able to remotely turn on/off the output relay using "Switch Binary." But what I really want to be able to do is use the input signal (SIG1) on the MimoLite to send a trigger signal back to HS3. I can see the green LED on the MIMOLite turn off/on when I manually short the input terminals (+/-) on the MIMOLite... this makes be beleive that the MIMOLite is triggering correctly, but I do not see any status changes within HS3. Can anyone help me confirm that the MIMOLITE is setup correctly within HS3? I also have a similar question into the Homeseer Helpdesk and FortrezZ folks to see if they know what is going on...FortrezZ Meter Pulse Node 5 Child
Andy
