Import will not add devices
    Spud-
    I was attempting to change 4 devices in my ubp configuration, so I deleted the old devices and then restarted the plug in. The devices will not recreate. These are devices 13,37,126, and 134.
    I have attached the log with debug entries as well as UPE file.
    Any ideas?
    Additional information
    Earlier posting accidentally truncated UPB debug log. Here is the more complete log.
    Note multiple errors at 8:52:11. I am using upstart 8.1.99.
    Program information:
    Current Date/Time: 10/26/2017 1:42:58 PM
    Operating System: Microsoft Windows Embedded Standard - Work Station
    System Uptime: 0 Days 15 Hours 26 Minutes 23 Seconds
    IP Address: 192.168.1.5
    Number of Devices: 1681
    Number of Events: 223
    Available Threads: 800
    Enabled Plug-Ins
    3.0.0.29: ADIO-100
    2.0.47.0: BLBackup
    1.0.3.0: BLShutdown
    3.0.0.37: EasyTrigger
    3.6.5.0: Harmony Hub
    1.0.0.9: HSInsteon
    3.0.6.16: Insteon
    3.0.0.47: ISYInsteon
    3.0.2.4: OMNI
    3.1.0.20: Sonos
    3.0.6429.13054: UltraLighting3
    3.0.6377.20892: UltraWeatherWU3
    3.0.0.40: UPBSpud
    3.0.0.21: VWS
    3.0.1.130: Z-Wave
      I don't see any of those device ids in your .upe file.
      Have you tried to export again from Upstart?
      What's the device names?
        Names
        I reexpoted under new name Arbutus11. (Attached)
        Names: Device 13 Library Sculpture Down
        37 Dining Table
        126 Master Bedroom Reading Lamp
        134 Her Sitting Shower
          found the problem, there is a bug in UPStart when exporting to the upe file. When it exports a repeater the subsequent device is messed up because the repeater is only one line in the file.
          I manually fixed your file (attached) and I will report the bug.
          As a workaround maybe there is a way in Upstart to not export the repeaters or group them at the end of the file...
            thanks
            I would have never found that.
              I reported the bug, and they want the upb file, could you send it to me?
              thanks
                send file
                How can I get it to you. It will not attach here.
                  spud.webb.4@gmail.com
                    File will not load
                    I opened the file you sent me in a text editor and saved it was a upe extension. I till not load in the plugin. Am I missing something?
                      you don't need to edit it in a text editor, just download it and change the extension from .txt to .upe in windows explorer.
