Hello Ultra,
Please could you consider to change or add option to change in settings of UltraNetatmo3 plug-in the API URL from
https://api.netatmo.net/
to
https://api.netatmo.com/
The reason is that on my Window XP system the ...net URL doesn't work even I have installed all current updates and root certificates. I am getting:
Debug~~!~~The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
Warning~~!~~Unable to get Netatmo Access Token.
I know that this issue has been discussed before and it was related to the root certificates. Unfortunately it seems that only way how to fix it on Windows XP is to change the URL of the API. I have tried to install all necessary root certificate updates without any success.
I can see the problem also in IE browser, which is saying that the api.netatmo.net SSL certificate is not correct. However Firefox is OK with the same certificate.
Fortunately https://api.netatmo.com/ is working in both cases and it can solve the issue for UltraNetatmo3 plug-in SSL connection.
Korim
to
Korim
