Hi guys,
I am trying to create an event which in its simplest form checks for the status of a hub, and if it is "PowerOFF" sets a virtual device ("Harmony Hubs ON/OFF Status") to OFF.
The hub and its devices are all correctly setup and the statuses show up correctly in the device manager. Also, I am able to control the Harmony Hub activity in the HS device manager using the dropdown. (Just to be sure, I deleted all of the devices, then rescanned both hub activities and devices as well).
The event is setup as follows:
IF event triggered manually
AND "HarmonyHub1_LR" = PowerOFF
THEN Set "Harmony Hubs ON/OFF Status" = OFF
I test as follows:
1) Turn on the hub to activity "Apple TV (Living Room)"
2) Manually turn on the virtual device "Harmony Hubs ON/OFF Status"
3) Run the above event
When I run the event, the virtual device turns OFF, which is not correct as the hub is not set to "PowerOFF".
I have tried various other tests to prove if the event reads the hub activity status or not, and in all cases the status seems to be ignored.
I have attached a screenshot showing the setup - any help would be greatly appreciated.
Dennis
I test as follows:
Dennis
