Originally posted by Jakob.Sand
View Post
Greig
Sent from my HTC One using Tapatalk
If (input signal == LOW) { wait for 500ms if (input signal still is LOW) { send status to homeseer } else { do nothing with this input } }
//********************************Input Setup******************************* byte InPinArray[30] = { 0 }; byte Debounce = 5000; byte count = 0; byte NoOfInPins = 0; int InStateArray [(sizeof(InPinArray) / sizeof(InPinArray[0]))]; unsigned long PrevDebounce [(sizeof(InPinArray) / sizeof(InPinArray[0]))]; void InputCheck(){ byte pinread; for (count=0;count<NoOfInPins;count++) { if(millis() - PrevDebounce[count] > Debounce){ pinread = (digitalRead (InPinArray[count])); if (InStateArray[count] != pinread){ InStateArray[count] = pinread; PrevDebounce[count] = millis(); SendByte(BoardAdd); SendChar(" I "); SendByte(count+1); SendChar(" "); SendByte(pinread); Sendln(); } } } }
case 'I': pinMode(Byte4, INPUT); digitalWrite(Byte4, HIGH); if (Byte3 > NoOfInPins){ NoOfInPins = Byte3; } InPinArray[Byte3-1] = Byte4; break;
//******* modification for input errors **************** 20151026 Alex Houben //*********************************Input Setup******************************* byte InPinArray[30] = { 0 }; byte Debounce = 300; byte count = 0; byte NoOfInPins = 0; int InStateArray [(sizeof(InPinArray) / sizeof(InPinArray[0]))]; unsigned long PrevDebounce [(sizeof(InPinArray) / sizeof(InPinArray[0]))]; void InputCheck() { byte pinread; [B] byte pinread2;[/B] for (count = 0; count < NoOfInPins; count++) { if (millis() - PrevDebounce[count] > Debounce) { pinread = (digitalRead (InPinArray[count])); [B] for (int w = 0; w < 10; w++) { delay (1); pinread2 = (digitalRead (InPinArray[count])); //digital read is approximately 9ms if (pinread != pinread2) { return; } }[/B]
