Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Blade Plug-Ins > BLLock (3P)
BLLock (3P) Discussion of BLLock plug-in
  #21
Old January 24th, 2018, 06:39 AM
Blade's Avatar
Blade Blade is offline
OverSeer
No promises but let me give it some thought
Can u add a feature request on my web site for this please
I do have quite a few feature requests that I still need to get to
Cheers,
Bob
  #22
Old January 26th, 2018, 08:25 PM
automatte automatte is offline
Seer
I am still getting the error on Linux .402:
HTML Code:
System.Web.Compilation.CompilationException
error : Unhandled Exception:
Description: Error compiling a resource required to service this request. Review your source file and modify it to fix this error.
Details: error : Unhandled Exception:
Error origin: Compiler
Error source file: /BLLock_activity.aspx
Exception stack trace:
  at System.Web.Compilation.AssemblyBuilder.BuildAssembly (System.Web.VirtualPath virtualPath, System.CodeDom.Compiler.CompilerParameters options) <0x6c76b658 + 0x0089c> in <filename unknown>:0
  at System.Web.Compilation.AssemblyBuilder.BuildAssembly (System.Web.VirtualPath virtualPath) <0x6c76b608 + 0x0001f> in <filename unknown>:0
  at System.Web.Compilation.BuildManager.GenerateAssembly (System.Web.Compilation.AssemblyBuilder abuilder, System.Web.Compilation.BuildProviderGroup group, System.Web.VirtualPath vp, System.Boolean debug) <0x6c782580 + 0x007a3> in <filename unknown>:0
  at System.Web.Compilation.BuildManager.BuildInner (System.Web.VirtualPath vp, System.Boolean debug) <0x6d007440 + 0x0043f> in <filename unknown>:0
Version Information: 4.5.1 (master/9db20c4 Fri May 13 15:41:42 EDT 2016); ASP.NET Version: 4.0.30319.42000
  #23
Old January 26th, 2018, 10:18 PM
Blade's Avatar
OverSeer
That is odd
I am running 402 on linux as well and it loads up fine for me
Show me the files in your [hs3 root]\html/bin folder
  #24
Old January 28th, 2018, 07:06 PM
Seer
Quote:
Originally Posted by Blade View Post
That is odd
HTML Code:
total 11040
-rwxr-xr-x  1 homeseer root      77 Mar 26  2015 autostart_hs
drwxr-sr-x  9 homeseer root    4096 Jan 17 16:11 bin
-rwxr-xr-x  1 homeseer root     271 Mar 26  2015 change_password.sh
-rwxr-xr-x  1 homeseer root   35310 Aug 24  2015 check_passwd
drwxr-sr-x  3 homeseer root    4096 Jan  9 22:59 Config
drwxr-sr-x  2 homeseer root    4096 Jan 10 15:37 ConfigBackup
drwxr-sr-x  8 homeseer root    4096 Jan 26 19:28 Data
drwxr-sr-x  3 homeseer root    4096 Jan  6 13:59 Docs
-rwxr-xr-x  1 homeseer root     683 Mar 26  2015 factory.sh
-rwxr-xr-x  1 homeseer root      54 Mar 26  2015 go
drwxr-sr-x  2 homeseer root    4096 May 16  2016 Grammar
-rw-r--r--  1 root     root 1073152 Aug  1 12:39 HAI.Controller.dll
-rw-r--r--  1 homeseer root   76288 Jan 17 10:10 HomeSeerAPI.dll
-rwxr-xr-x  1 root     root   21504 Nov 17 08:35 HS3Sentry.exe
-rwxr-xr-x  1 root     root   37376 May 16  2016 HS3SentryLinux.exe
-rw-r--r--  1 homeseer root   44032 Mar 26  2015 HSCF.dll
-rw-r--r--  1 homeseer root   13312 Jan 17 10:10 HSConsole.exe
-rw-r--r--  1 homeseer root    1518 Jul 19  2017 HSConsole.exe.config
-rw-r--r--  1 root     root  802304 Jan 22 17:41 HSPI_BLLock.exe
-rw-r--r--  1 root     root     358 May 10  2015 HSPI_BLLock.exe.config
-rw-r--r--  1 root     root  221184 May 29  2015 HSPI_HSTOUCH.exe
-rw-r--r--  1 root     root  909824 Dec 10 01:08 HSPI_MyQ.exe
-rw-r--r--  1 root     root    4784 Dec 10 01:08 HSPI_MyQ.exe.config
-rw-r--r--  1 root     root  507904 Sep 26 08:49 HSPI_OMNI.exe
-rw-r--r--  1 root     root     355 Aug  1 12:54 HSPI_OMNI.exe.config
-rw-r--r--  1 root     root  249344 Dec  3 20:59 HSPI_SKWARE_DEVICE_HISTORY.exe
-rw-r--r--  1 root     root    1538 Aug 13 14:17 HSPI_SKWARE_DEVICE_HISTORY.exe.config
-rw-r--r--  1 root     root 3139584 Jan  4 18:38 HSPI_ZWave.exe
-rw-r--r--  1 root     root     357 Dec 18  2012 HSPI_ZWave.exe.config
drwxr-sr-x 15 homeseer root    4096 Jan 26 19:01 html
-rwxr-xr-x  1 homeseer root      36 Mar 26  2015 install.sh
-rwxr-xr-x  1 homeseer root     408 May 16  2016 led.sh
drwxr-sr-x  2 homeseer root    4096 Jan 26 19:07 Logs
-rwxr-xr-x  1 homeseer root  930816 Mar 26  2015 Mail.dll
drwxr-sr-x  2 homeseer root    4096 Jan  4 20:00 Media
drwxr-sr-x  2 homeseer root    4096 Jan 17 16:11 mochad
-rwxr-xr-x  1 root     root     606 Aug 24  2015 password_check.c
-rwxr-xr-x  1 homeseer root      22 Mar 26  2015 play_audio.sh
-rwxr-xr-x  1 homeseer root     488 Mar 26  2015 register_with_find.sh
-rwxr-xr-x  1 homeseer root     487 Sep 28 13:41 restart.sh
-rw-r--r--  1 root     root  126976 Dec 10  2012 RssToolkit.dll
-rwxr-xr-x  1 homeseer root      14 Mar 26  2015 run_command_raw.sh
-rwxr-xr-x  1 homeseer root      44 Nov  9 09:46 run_command.sh
-rwxr-xr-x  1 root     root 2852352 Jan 17 10:10 Scheduler.dll
-rw-r--r--  1 homeseer root    1594 Jan 17 10:10 Scheduler.dll.config
drwxr-sr-x  2 homeseer root    4096 Jan  4 20:00 scripts
-rwxr-xr-x  1 root     root    2509 Dec 16 12:39 server.pfx
-rwxr-xr-x  1 homeseer root     405 Mar 26  2015 shutdown_controller.sh
-rwxr-xr-x  1 homeseer root      31 Mar 26  2015 shutdown.sh
-rwxr-xr-x  1 homeseer root      38 Mar 26  2015 speak.sh
-rwxr-xr-x  1 homeseer root      32 Mar 26  2015 speak_to_file.sh
drwxr-sr-x  2 homeseer root    4096 Jan  4 20:00 temp
drwxr-sr-x  2 homeseer root    4096 Mar 26  2015 Temp
-rwxr-xr-x  1 homeseer root     195 Mar 26  2015 updatehs.sh
-rw-r--r--  1 root     root   56988 Jun 17  2016 updater.txt
drwxr-sr-x  3 root     root    4096 Jan 26 19:08 Updates3
-rwxr-xr-x  1 homeseer root     493 Mar 26  2015 update.sh
drwxr-sr-x  3 root     root    4096 Jan  4 21:35 usr
drwxr-sr-x  2 homeseer root    4096 Mar 26  2015 Wave
drwxr-sr-x  2 homeseer root    4096 May 16  2016 wave_files
  #25
Old January 28th, 2018, 07:08 PM
Blade's Avatar
OverSeer
I need to see the html\bin folder
  #26
Old January 28th, 2018, 07:30 PM
Seer
Sorry, thought I was in html/bin
HTML Code:
Anthem.dll
CSScriptLibrary.dll
HomeSeerAPI.dll
HomeSeerUtil.dll
HSCF.dll
HSPI_BLLock.exe
Mail.dll
Mono.CSharp.dll
RssToolkit.dll
Scheduler.dll
sqlite3.dll
SQLite.Interop.dll
System.Data.SQLite.dll
  #27
Old February 26th, 2018, 05:14 PM
mkaplan1 mkaplan1 is offline
Seer
real time log error
I'm getting the same error with real time logs
I was using plugin version 3.0.8.0. I disabled it, restarted HS and upgraded to 3.0.11.0.
I know it has something to do with Mono since I'm getting same error using a number of Jon00's scripts, but HS isn't interested in helping me fix the issue.
  #28
Old February 26th, 2018, 05:43 PM
Blade's Avatar
OverSeer
Hmmm I am getting this now in Linux as well
Mine was working fine before so it is not just you
HTML code is Off
How to see real-time HS3 log files? simonmason HS3 / HS3PRO Discussion 8 March 13th, 2017 02:14 PM
Real Time Clock tarbat HomeTroller Zee 12 November 5th, 2014 11:31 AM
Really want Real Time Log BarryP HomeSeer General Discussion Area 5 March 18th, 2007 06:01 PM
Projected Time is real time ka7gzr mcsSprinklers 6 June 11th, 2006 07:53 PM
Real Time Clock CFGuy Script & Plug-In Library 0 September 13th, 2005 09:31 PM
