I have modified the PI (current ver 1.0.16) to improve the "Fan" device to be more inline with what is actually happening with the hvac system.
What is new:
-the Fan device (dc 2) will change to "On" when the system status is heating, cooling or the Fan Mode is set On.
-when the fan mode is Auto, the Fan device will now report correctly as well.
- the Fan triggers are also working correctly (Fan Starts Running, Fan turns Off)
-added device values to the Fan device, 0-Off, 1-On.
I have tested it with my RC-80B, but am looking for others to test with their HAI stats.
Any takers?
I would recommend saving your current HAI plug-in and HS database, etc before preceeding. That said, I did not have any problems putting this new version into my production environment.
To install, Just download the attached zip, shutdown HS, replace the current hspi_haithermostat.dll with the new one in the zip, and restart HS. everything should come up just as you left it.
Please leave me feedback with the HAI RC model you are using, what version of HS you are using, and any problems you encounter.
What is new:
Any takers?
