I have this plugin running fine for over 3 years. Then in July of this year it stopped working. I have tried different com ports, rewired the linkage, tried a new IT 100 board, and nothing has helped. I also tried the HS DSC plugin and could not make it work either. The system works fine from the two DSC PK5500 panels in my house. I would be thankful for any ideas that anyone has at this point short of changing out the DSC 1832 panel.
Plug in no longer works for me.
Originally posted by NicolaiL View PostHave you tried connecting with something like putty to prove that the connection from the it-100 to your HS3 is working?
See here for Putty: http://www.chiark.greenend.org.uk/~sgtatham/putty/. It's a tool you can use to connect to the com port and see the data come in from the IT-100 to confirm that is working.
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
The point is you should be able to connect with putty on the relavant COM port. You should see traffic from the IT-100 on a regular basis. Once you see traffic you will know the IT-100/RS232 cable/PC COM Port is working.
If you get this far then the problem will be with the plug-in/config but putty is a helpful tool to troubleshoot the IT-100 setup.Nicolai L
Originally posted by donstephens View PostDon't mean to hijack this conversation, but how do you use putty to monitor a COM port?Nicolai L
Originally posted by Rotech View PostI had to ask the blade for a older rev. Because the latest didn't work for me.
Did you get the plug in working with an older version. I am beginning to suspect a win 7 issue with some update that occurred in July. I have not rolled the win 7 updates back off my machine but am thinking of it.
Mark
