Jon00 Remote Computer Control & Network Monitor (HS2, HS3 & HS4)
    Originally posted by ESSCHENK View Post
    Hello Jon,
    Thanks for the answer for now this solution works
    My wife is also very happy with this app
    Now when she is on internet I can automatic sent message to the screen
    Now she can see when the washing machine is ready
    Ore when somebody is on the frontdoor.
    Etc etc
    Thanks Ed
    Ps
    Coffee and cake is underway
    Thanks very much Ed. Glad you like it.
    Jon
      Originally posted by efrey View Post
      Jon,
      Would this work to monitor and control the HS2 computer itself? Specifically, remotely reboot and restart HS2 remotely over the internet?
      Here is the scenario:
      - HS2 is running in a 2nd home.
      - Observe that occassionally the Zwave interface gets hung and have found that a reboot of the computer fixes the problem.
      - From a computer connected to the internet (remote to the 2nd home), reboot the HS2 computer and have HS2 application start when the computer restarts.
      Ernie
      If you want, I'll add optional Dynamic DNS and IPAddress match list to the client. That way it would only respond to recognised IP addresses for security. Anyone else interested in this feature?
      Jon
        OK, I have now added this feature. Just waiting for any bug reports before I release the next version.
        Jon
          Hello Jon,
          I have play several hours with the plugin,
          There are some nice features with this plugin.
          I Have noticed that when i start a pc then i cannot see if the pc is turned on
          Because i have not logged in
          So is there a possibility to deal with that
          This is only with remote control
          With network monitor i see the device when the recurring event started
          Ed
            I'm not sure I can deal with that. The client would probably need to be installed as a service but I do not have the tools for that.
            Jon
              #21
              Jon,
              Ok i understand
              Ed
                #22
                Hello Jon,
                I have found a way to load the client before the login.
                Maybe useful for some other people
                Make a scheduled task and use the option start before login.
                This works perfect without the need of extra programs.
                And no need to load as a service
                Ed
                  #23
                  Thanks for that Ed, I'll add that to the documentation.
                  Have you found any more uses for this?
                  Jon
                    #24
                    @Jon,
                    Plugin looks great.
                    Hoop the .net ping bug is not a problem in your plugin.
                    as Ed posted before this is a great combination of all the available scripts plugins in one controle.
                    Are there any OSX or printers commands that can be used?
                    or check the printer queue if there is any turn on the printer.
                      #25
                      Only time will tell regarding the bug but I have not had a problem. If you have encountered this issue, perhaps you would be a good candidate to test?
                      As I don't own a MAC, I have never looked into OSX. At present, no it is not supported.
                      Jon
                        #26
                        Downloaded documentation's looks good lot tuning options.
                        Will report if found any problem.
                        at the moment 80% of my domotica hardware is down because of a renovation.
                          #27
                          Hey John,
                          Hibernate and Sleep appear to do the same thing. I added Button 11 and 12 for Hibernate and Sleep.
                          I used the hibernate command for the button. Hibernation is enabled on the PC.
                          Transitioning to HS3Pro .298 - WinXPEmbedded
                            #28
                            Originally posted by Dafunktyfunk View Post
                            Hey John,
                            That may be the case ....it depends on the version of Windows you are using. I think XP uses both.
                            Jon
                              #29
                              I was going to post about this, but thought I screwed up something on my end...have to check the problem area between the keyboard and chair first!
                              If this doesn't get resolved, I'll just fire a command to a program called powerdown. It will properly hibernate my PC. It's what I used until I started to play with this!
                              --Dan
                                #30
                                Dan,
                                What are you having problems with..hibernation?
                                Jon
