ISY Insteon 3.0.0.54 - Beta 54 for HS3
    Announcing version 3.0.0.54 Beta of the ISY Insteon Plug-in for HomeSeer 3.0.
    Starting with release 3.0.0.43, the ISY Insteon Plug-in beta is now available via the starndard HomeSeer update process. This should simplify the update process and make getting the latest version more automatic. The normal HomeSeer update process will now notify you when an update is available. One step closer to a production/gold release. I'll keep the 3.0.0.42 version attached here for a while, along with the instructions to roll back to it should there be problem with this new process.
    Updating the plug-in on Linux has a known issue where the plug-in will fail to automatically restart following the update. Toggling the plug-in to stop and then restart it manually will properly restart the plugin.
    The ISY Insteon Plug-in will show up under the Beta section of the plug-in list.
    This version is set to expire on May 20th, 2018
    Installation
    1. Go to the HomeSeer PLUG-INS / Manage web page
    2. Click on the "Update Listing" button near the bottom (information on available plug-ins will download)
    3. Click on the yellow circle with triangle to expand the listing
    4. Scroll down to the bottom and click the yellow circle with triangle for "Beta(see forums.homeseer.com for details on using anything in this section).
    5. Check the box next to ISYInsteon Plugin<li>Update application config file so that it should run on Linux again.
    <li>Convert SQLite based config database to a file based system to remove dependnecy on SQLite. The SQLite DLL's distributed with the package don't work on Linux. They also may be the cause of some of the failures after updating. A future version will remove the SQLite dependencies completly.
    <li>A couple of REST communication changes to improve ISY communication on Linux based systems.
    <li>Stop trying to auto-detect an ISY when no host/ip address has been configured (I.E on first time install). This was just delaying the startup sequence and amaking initial installation problematic. The ISY hasn't supported this capability in a long time anyway.
    <li>Make the function list in the debug/logging configuration screen hidden when tracing is not selected. This makes the configuration screen a lot cleaner looking under normal use.
    <li>Report battery level events when status messages are enabled.
    6. Scroll back up near the top of the page and press the "Download and Install" button
    7. Watch the plugin download and install.
    Manual Installation of version 3.0.0.42
    1. Download the ISYInsteon_3_0_0_42.zip file and place in your HomeSeer3 Updates3/Zips folder.
    2. Download the updater_override.txt file and place it in your HomeSeer3 folder
    3. In HS3, go to the Plug-ins tab -> Manage ->Update Listing page and look for the yellow arrow(additional interfaces). and click the "Update Listing" button. You should only see the update for the ISYInsteon plugin. Check the update and install. It will install from the local zip.
    4. To return to normal updates, remove or rename the updater_override.txt file you placed in your HomeSeer3 folder.
    New in 3.0.0.2
    - Fixed database creation for new installations.
    - Fixed but in trace function table creation.
    New in 3.0.0.3
    - Fixed bugs in scene/program/variables/network resource type devices.
    New in 3.0.0.4
    - Network resources now have a "Run" control button to activate them.
    - Fixed the broken button the debug/trace configuration tab.
    - Status message filters now take effect immediately when they are saved.
    - Added a control for variables for setting the variable value.
    - Improved value reporting so all devices should now show the proper values on the device management screen.
    - Use the correct values for on/off on all toggle type devices.
    - The plug-in management page will now show that the plug-in is initializing while it is initializing as will the plug-in's status page. While the pug-in is initializing the values may not yet be updated and you are not able to control devices.
    New in 3.0.0.5
    - Reworked how the HomeSeer device records are handled when the plug-in starts. Primarily to prevent the overwriting/removal of user modified value/status pairs.
    New in 3.0.0.6
    - Fixed location setting "Do Not Set". It was clearing the location field instead of leaving it set to current value.
    - Updated access control devices (specifically locks) to use the proper commands so that they can now be locked and unlocked through HomeSeer.
    - Added latest Insteon devices types so that they are properly recognized by the plug-in.
    New in 3.0.0.7
    - Fixed bug where new weather module data would cause a crash (ISY firmware 4.2.3)
    - Added support for new weather module data, including forecast data.
    New in 3.0.0.8
    - Cleaned up the weather data a bit.
    - Z-Wave thermostats should now report the correct temperatures.
    New in 3.0.0.9
    - More updates for weather data, includes today's forecast data.
    - Fix for value/status pair for relay devices now on = 255
    New in 3.0.0.10
    - Fixed thermostat current operating status. Previously the plug-in created both a "state" and a "call" device for the thermostat. These were intermixed and neither was working correctly. The "state" device has been removed leaving just the "call" which should now reflect the actual state; cooling, heating, or off.
    - Fixed the thermostat fan device display. it should now display Auto or Off, not 8% dim or 7% dim.
    - Fixed there thermostat humidity device. It was reporting the humidity 1% less than actual.
    - Fixed z-wave dimmer device control. You can now turn dimmers on/off and set the dim level.
    - Fixed control/status of the Insteon Fan/Switch.
    New in 3.0.0.11
    - Added error handing for REST calls.
    - Fixes in the program handling during restarts.
    New in 3.0.0.12
    - Better logging when the plug-in starts to catch early issues
    - The plug-in no longer tries to autodetect an ISY on the network when it starts. Recent ISY firmware disables this ability by default and it would lead to time-out errors startup.
    - Fixed scene toggle on/off
    - Updated EZIO devices to properly configure the inputs and outputs (I hope)
    New in 3.0.0.13
    - Clear out device status/value pairs before adding a new device.
    New in 3.0.0.14
    - Correctly set status-only for EZIO2x4 device nodes.
    New in 3.0.0.15
    - Allow on/off commands to EZIO output devices.
    New in 3.0.0.16
    - Triggers. The ISY specific triggers are now available. When creating trigger events in HS, you can now trigger on most of the message types that the ISY sends to the plug-in.
    New in 3.0.0.17
    - Fixed bug in device triggers. The device address wasn't being used to match against the created triggers. Thus, any device sending a specific event would match and fire a trigger created for that event.
    New in 3.0.0.18
    - Fix for MorningLinc lock commands.
    - Added Elk module event message parsing for Armed events.
    New in 3.0.0.19
    - Updated expiration date
    New in 3.0.0.20
    - Added new control for Programs, "Run". This causes the ISY to evaluate the program condition and then run the corresponding then or else set of commands.
    - Added some devices to to the "ISY Device Actions" event actions. This is still experimental but does allow for setting variable values from event actions.
    New in 3.0.0.21
    - Alphabetize the device names in the Event Action list selection.
    - Added save button and header to device filter configuration tab.
    - Fixed bug where hidden devices would not show up as hidden on the configuration tab if the device still exists in HomeSeerr.
    New in 3.0.0.22
    - Update variable device parsing to ignore new "prec" attribute to eliminate warning messages.
    - Change how program status is queried. The ISY is not returning the status for all programs when using the original method.
    - Don't clear any user specified status/graphics pairs on variable type devices.
    New in 3.0.0.23
    - Ignore ISY messages about billing since they won't be handled by the plug-in
    - Fixed program 'Run" button / command. This was executing the 'then' part of the program instead of processing the conditional and running the appropriate part based on the state of the conditional.
    - Removed the CONFIG_CHANGE debug message that was accidentally left in the code.
    New in 3.0.0.24
    - Fixed bug in program actions that prevented certain actions from working (enable, disable, stop, run at reboot, not run at reboot)
    - Added some error checking to the program trigger functions to try and prevent the plug-in from crashing.
    New in 3.0.0.25
    - Implemented the PollDevice entry point. This currently only returns the plug-in's status for each device and does not go out and re-query the ISY for any updated status.
    - Updated the "Parse Failure" message so that it doesn't sound so dire. In most cases, this message simply indicates that the ISY is sending something new that the plug-in is not going to handle. The ISY message will be ignored with no impact to existing functionality.
    - Ignore battery level messages from the ISY and no longer report an parse failure.
    New in 3.0.0.26
    - Initial support for the On/Off Outlet device. I don't believe this impacts anything else, but if you're not interested in testing the On/Off Outlet support, skip this version.
    New in 3.0.0.27
    - Proper support for the Insteon On/Off Outlet device.
    New in 3.0.0.28
    - Removed the log level setting from the main configuration tab
    - Renamed the debugging configuration tab to reflect that this is where you configure the log level now.
    - Fixed a bug where copying an event didn't quite work as the copied version was sharing configuration with the original.
    - Improved error messages and debug messages in the event initialization code.
    New in 3.0.0.29
    - Improved the status/values for textual weather values like condition, coverage, intensity.
    New in 3.0.0.30
    - Fix bug introduced in 3.0.0.29 where it will add 2 additional (undefined) weather values on each restart.
    New in 3.0.0.31
    - Fix handling of weather last update time message and HS device creation.
    New in 3.0.0.32
    - Optimize hide device configuration. It would try to update all devices, even if only one device was changed to hidden. 20+ seconds per 100 devices. Now less than 1 second for 100 devices.
    - Fix sort buttons on hide device configuration page. The buttons will now cause the list to re-sort without having to manually reload the page.
    - Fix bug where it was impossible to hide the first device.
    - Extend expiration date
    New in 3.0.0.33
    - Fix select all / de-select all in configuration screens when using the Internet Explorer browser.
    - Fix a bug where switching a device from hidden from HS to visible would not really take and device would still show as hidden on restart.
    New in 3.0.0.34
    - Finally, thermostats work with HSTouch. A new device will be added for each thermostat with a suffix of '- root'. The other thermostat devices nodes will get added to the new device as child devices.
    New in 3.0.0.35
    - Tweaks to the thermostat devices to better match what HSTouch expects.
    - Improve performance when programs are added/deleted/renamed.
    New in 3.0.0.36
    - Fix a bug in event actions building the device list for ISY Device actions would crash if it encountered a duplicate name.
    New in 3.0.0.37
    - Change 240v load controllers to relay devices so that they can be controlled.
    - Changed how variable devices are configured in HomeSeer. This change may cause changes to some user defined value/status pairs. The changes should be limited to variable type devices.
    New in 3.0.0.38
    - Support for running on Linux. The changes to support running on Linux were fairly minor and don't impact the ability to run on Windows.
    - Fixed bug in triggers when trying to setup multiple trigger conditions using "Or If".
    - Improved the expiration process. It now will warn for 7 days after the plug-in has expired before disabling the plugin. It will also attempt to email if there's a default "To" address configured in HomeSeer. This does require that HomeSeer be configured properly to send email.
    - Re-organized the plug-in startup code. This is the largest change but mostly just involved moving code around. It should improve the robustness of the start up and possibly improve the start up performance a bit.
    New in 3.0.0.39
    - Fix up formatting and sort order for trigger device lists.
    New in 3.0.0.40
    - Fix scene On/Toggle actions in events. Possibly a due to a change in ISY firmware 5.x.x, trying to turn a scene ON would result in it getting sent an OFF command.
    - Add support for "transfer-encoding: chunked" that has been added to the 5.0.0.9 ISY firmware. The plug-in should function properly when this feature is enabled in the ISY firmware.
    New in 3.0.0.41
    - When running an ISY program, wait for it to complete before sending other commands.
    - Minor log message improvement while mapping ISY and HS devices at init.
    - Ignore portal status messages (instead of reporting parse failure).
    New is 3.0.0.42
    - Wait for program commands to complete before sending device commands.
    - If sending a device command fails with a 501 error, retry sending the command as the ISY may just be busy.
    - Make triggers for program start/stop/enable/disable actually work.
    - Add support a couple of new keypadlinc dimmer devices.
    New in 3.0.0.43
    - A bug in the keypad grouping code would cause the plug-in to crash during initialization if any keypads were hidden from HomeSeer. This is now trapped and only generates a (bogus) error message.
    - Removed the bogus error messages on startup related to variable queries.
    New in 3.0.0.44
    - Properly handle hidden keypad devices when trying to group the buttons.
    - Don't wait for a response from commands sent to control a scene.
    New in 3.0.0.45
    - Handle device replacement properly. When doing a device replace on the ISY, attempt to do the same on HomeSeer.
    - Add ability to "lock" HomeSeer device records so that the name/location fields won't be overwritten when the plug-in initializes. See the device filter configuration page for the lock checkbox.
    New in 3.0.0.46
    - Update application config file so that it should run on Linux again.
    - Convert SQLite based config database to a file based system to remove dependnecy on SQLite. The SQLite DLL's distributed with the package don't work on Linux. They also may be the cause of some of the failures after updating. A future version will remove the SQLite dependencies completly.
    - A couple of REST communication changes to improve ISY communication on Linux based systems.
    - Stop trying to auto-detect an ISY when no host/ip address has been configured (I.E on first time install). This was just delaying the startup sequence and amaking initial installation problematic. The ISY hasn't supported this capability in a long time anyway.
    - Make the function list in the debug/logging configuration screen hidden when tracing is not selected. This makes the configuration screen a lot cleaner looking under normal use.
    - Report battery level events when status messages are enabled.
    New in 3.0.0.47
    - Fix failure when event filter config is missing.
    - Add command line argument to set the initial log level.
    - Don't crash if SQLite config database doesn't exist.
    - Fix bug where initialization doesn't finish after entering ISY ip address and account information for the first time.
    New in 3.0.0.48
    - Add new ControlUse values to thermostat and access control devices. This should allow for control of the thermostats and locks via third party controllers.
    - Add thermostat child node associations to the root node
    New in 3.0.0.49
    - Add range controls for the thermostat setpoints. This and the above two changes should make Insteon thermostats controllable via Google Home, Amazon Alexa and IFTTT.
    New in 3.0.0.50
    - Create device associations between scene devices and the scene members.
    - Add fast on / fast off buttons to devices that support those commands.
    New in 3.0.0.54
    - Fix bug with firmware version checking. It would fail on ISY firmware versions that contained a letter (I.E. 5.0.10E).
    - No longer try to create associations for scenes that don't have any members. This could cause the plugin to crash.
    - Fix a bug where the plug-in would crash when it tried to create scene/member associations for scenes that were hidden from HomeSeer.
    - Add ability to configure what controls are available for some devices.
    - When using the device filter configuration screen to hide devices from HomeSeer, the HomeSeer records are deleted by the plug-in so they don't don't need to be deleted manually after setting the device hidden.
    - Add some text description of what hidding/locking devices actually does.
    Last edited by bpwwer; January 5, 2018, 01:31 PM. Reason: bug fixes / new features
    Bob Paauwe
    ISYInsteon Plug-in
    Hello Bob,
    Thank you for sharing your first version of your ISY HS/3 plugin with us!
    However, I'm having a bit of a problem installing it. I've downloaded and placed the ZIP file into the Updates3 folder and the Updater_Override text file in the main HS/3 folder, but when I check the box on the test plug-in, HS comes back with the following error code:
    Error downloading file: The remote server returned an error: (404) Not Found.
    I must be missing a step or something.
    -Todd
    ____________________________________________________________ ________________
    HS2Pro: 2.5.0.81 :: HS3Pro (beta) || Plugins:| SmartHome PowerLinc USB, Global Cache, BLBackup, DooCPU Monitor, DooMotion, BLOutlook, BLIcon, BLOutgoingCalls, OutgoingCalls, ROC-Rnd, HSTouch iPhone, UPS Monitor, DooMenuBar, BLSpeech, HSTouch Server, WAF AB8SS, mcsTemperature, VWS, BLChart, RFXCOM, ISY Insteon, iAutomate RFID, iTunes, NetCAM, DSC Security, Nest
      Thanks for trying it!
      Looks like I attached the wrong version of the updater_override.txt file. It was trying to update from HomeSeer instead of using the local .zip.
      This is how HomeSeer now recommends that test versions are distributed/installed so there may be a bit of a learning curve as I figure it all out.
      Originally posted by tmcgowan View Post
      Hello Bob,
      Bob Paauwe
      ISYInsteon Plug-in
        Hello Bob,
        I was able to install your plug-in with the new updater_override file. However, after installing it and restarting HS3, I get the following pop-up error:
        "HSPI_ISYInsteon has encountered a problem and needs to close. We are sorry for the inconvenience."
        Once I get rid of the error message and HS completes it's boot process, I go to the Manage Plugins page and enable the plug=in, I get the following status message:
        "**FATAL**: Failed getting InterfaceStatus from ISYInsteon - the interface was not found in the list of active interfaces."
        I've also noted that ISYInsteon name doesn't ever appear in light blue, indicating that you set its parameters. There's also no ini file created in the Config directory.
        Hopefully, you can use this information to diagnose the problem.
        -Todd
          Hello Bob,
          I'm seeing the same thing.
            I'm not able to reproduce this. I think I've removed everything related to the plug-in and re-install it and it works fine.
            It sounds like the plug-in is crashing as soon as it tries to start, but without more information I really don't know why. Plug-in in HS3 are standalone console applications so you can try running it by just double clicking on the HSPI_ISYInsteon.exe file in the HomeSeer 3 folder from explorer. It should open a console window with a couple of start up messages. Or if it fails, maybe it will give some indication why it failed.
            Bob Paauwe
            ISYInsteon Plug-in
              I just re-uploaded the zip file. The only difference is that this time I built the plug-in as a release build instead of a debug build.
              Should just need to follow the same steps as before to install this copy. (or you could unzip and just copy the HSPI_ISYInsteon.exe file to the HomeSeer folder, replacing the copy that's there and then double click on the file to run it.
              Bob Paauwe
              ISYInsteon Plug-in
                Hello Bob,
                I tried you latest version of the build, however I had the same results as in my previous posting. The interesting thing is that the HS Log shows the install going along fine, but it never registers the plugin's failure event:
                Dec-15 1:56:16 PM Plug-In Finished initializing plug-in ISYInsteon
                Dec-15 1:55:56 PM Updater Install/Update of package ISYInsteon Plugin was successful.
                Dec-15 1:55:56 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\Bin\ISYInsteon\SQLite.Interop.dll
                Dec-15 1:55:56 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\Bin\ISYInsteon\System.Data.SQLite.dll
                Dec-15 1:55:56 PM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_ISYInsteon.exe
                Dec-15 1:55:56 PM Updater Installing package ISYInsteon Plugin
                Dec-15 1:55:56 PM Updater Using local file: HSPI_ISYInsteon_3_0_0_0.zip
                Dec-15 1:55:56 PM Updater Downloading update: ISYInsteon Plugin
                Dec-15 1:55:56 PM Updater Starting download of updates
                BTW I'm running the most recent version of HS/3 (.54) and I have all other plugins disabled to keep things simple at the moment.
                -Todd
                  Just uploaded another copy with some addition print statements in the initial startup section to see if we can pin down what's happening.
                  Plug-in's for HS3 are now stand-alone windows console applications. They don't get loaded into HomeSeer anymore but run as a separate programs that communicates with HomeSeer over the network.
                  It sounds like the ISYInsteon program is dying before a connection with HomeSeer is established, thus you wouldn't see anything in the HomeSeer logs about it.
                  So please try the following with this version:
                  1) after it has installed (and I'm assuming crashed again). Simply double click on the HSPI_ISYInsteon.exe program in the HomeSeer directory. This should open a console and display some messages. If it dies and closes the window before you have a chance to see any of those messages, try the next step.
                  2) Open a command prompt and change to the HomeSeer folder. Then from the command prompt run HSPI_ISYInsteon. That should display the startup messages in the command prompt.
                  What it should display is:
                  Plugin: ISYInsteon Instance:  starting...
                  ISYInsteon Connecting to server at 127.0.0.1...
                  Connection attemp 0
                  Connected to HomeSeer at ip address 127.0.0.1
                       Host API version = 3
                       Callback API version = 3
                  ISYInsteon 3.0.0.0 will expire on 1/10/2014 8:00:00 AM
                  ISYInsteon Connected, waiting to be initialized...
                  Bob Paauwe
                  ISYInsteon Plug-in
                    Hello Bob,
                    Here's a screen image of the error message I received:
                    -Todd
                      Hello Bob,
                      Thanks! That helps a lot. One more question - can you post what's in your HomeSeer 3 folder, just the top level? I'm wondering if mine has stuff in there from earlier development releases of HS3 that aren't in there now.
                      Bob Paauwe
                      ISYInsteon Plug-in
                        Sure. I'm keeping HS/3 pretty clean until I get my ISY working, so the plug-in interaction should be pretty minimal. The only other thing that might be coming into play is that I have HS/2 running on the same machine. I've tried running just HS/3, but the plugin has the same problems as before.
                        Here is my HS/3 Directory Listing:
                        -Todd
                          Apparently I'm not the only one that has had this type of problem when first distributing a plug-in.
                          I just replaced the zip file in the first post with a new version. This one adds a file, HSPI_ISYInsteon.exe.config, that should get installed in the HS3 folder along side the HSPI_ISYInsteon.exe file. It is supposed to tell the program where to find the .dll files that it needs.
                          Looks like I do have some old files sitting around in my HS3 folder and it was using those files when I test.
                          Should be good now.
                          Bob Paauwe
                          ISYInsteon Plug-in
                            Great news, it's working!!
                            Thanks Bob!!
                            -Todd
                              Hi Bob,
                              Your plug-in added all 191 of my devices just fine. On/Off and Dimming seem to work just fine, but the status indicators show "Off" no matter what the real status is. I can also report that your plug-in works on an old HomeTroller Series 1 with just .net 4 installed. I could never get the previous .net versions to work with the XP embedded system.
                              Best regards,
                              Todd
                              -Todd
