Posted v0.4
- PlcBus device status change logging
Each PlcBus device status change is logged to the HomeSeer event Log.
If you don't want some device to be logged, you can use the "NO-LOG" checkbox in the HomeSeer device configuration page.
- New PlcBus Scene Device status string.
In addition to the On/Off scene status, PlcBus scene devices have a status string describing the recorded scene programming.
Exemple status for scene D8:
[255-D2] 28%
[255-D3] 35%
[255-D4] Off
If you add devices to the scene, the status string is updated with new devices.
If you erase scene addresses from a module, scene status strings are also updated.
- PlcBus scene ON/OFF status is automatically set to OFF when one of the scene devices has a status different from the scene settings.
Exemple with the above scene definition:
If I click Scene D8-ON, we get the following status:
D8 On
D2 Dim 28%
D3 Dim 35%
D4 Off
If D2, D3 or D4 status is changed, for example if I switch ON D4, then Scene D8 status is set to Off.
- New Scene programming mode. Scene programming has never been easier !
If you create a PlcBus User HomeSeer Device, you get a new toggle button "Show Scene Prog" / "Hide Scene Prog"
If you click "Show Scene Prog", you will get new buttons on PlcBus devices.
Scene devices have 3 new buttons:
"Add currently 'On' devices has On" --> This button adds all currently On devices to the scene, recording the ramp rate and dim level
"Add currently 'On' devices has Off" --> This button adds all currently On devices to be switched Off when the scene is activated.
"Remove currently 'On' devices" --> This button removes currently On devices from the scene.
Lamp and Appliance devices have one new button:
"Erase all scenes Addresses" --> This removes the module from any scene programming.
[255-D2] 28%
[255-D3] 35%
[255-D4] Off
D8 On
D2 Dim 28%
D3 Dim 35%
D4 Off
