Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Blade Plug-Ins > BLTVGuide
BLTVGuide Discussion of BLTVGuide plug-in
Old October 27th, 2014, 10:42 PM
kenrad's Avatar
kenrad kenrad is offline
BLTVGuide doesn't speak reminders
Trying to start out with a simple setup and just have the PI speak my reminders 15 minutes before the show starts but it does not speak the listing appears in the lineups and the reminders populate in the virtual device but I get nothing sent to the speaker client is anyone else seeing this or am I possibly missing a setting
Need a little help
Cheers Ken
HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Old October 28th, 2014, 03:26 AM
sparkman's Avatar
sparkman sparkman is offline
Hi Ken, I've tried it and it's working for me. Maybe post a screen shot of your reminder. Are you using the HS speaker clients, or a different speech proxy? Have you turned on any debugging on your speak proxy to see if it's received/generated?
Cheers
Al
Old October 28th, 2014, 05:28 AM
Blade's Avatar
Blade Blade is offline
Mine have been working as well for weeks. I am using BLSpeech for my speaking with no issues. My reminders have not been missed yet.
Cheers,
Bob
Old October 29th, 2014, 04:55 PM
kenrad's Avatar
I am using hs speaker clients and in the log on the speaker client it doesnt look like the speech is ever be9ng sent
Old October 29th, 2014, 06:23 PM
Blade's Avatar
Log a help desk ticket and attach a debug log zipped capturing the issue
Old October 29th, 2014, 10:49 PM
kenrad's Avatar
here is a screen shot of the reminder that I am using it is never spoken by HS3. as for a debug log im not even sure what to capture because it seems like nothing is being sent at all to the speaker client
Cheers Ken
Old October 30th, 2014, 05:38 AM
Blade's Avatar
For the debug log you will need to find out what time the favorite airs and then adjust the minutes before so that you do not have to wait too long for it to speak. That is how I tested the plugin.
I need to see a debug log of when it is supposed to speak x minutes before the reminder or favorite. It has to be something on your end because my reminders and favorites have not missed once since I have been using the plugin for almost a month now.
Old October 30th, 2014, 11:29 PM
ORNVM ORNVM is offline
I've had this issue also using the default homseer speech client on a dedicated android WFTT7.
at first i thought it was just for some reminders that i originally made before the speak option was added and by deleting and re-creating it started, but since then i've had other issues of it not speaking, but the reminder is listed and the virtual device is updated correctly.
I checked logs too and not seeing anything, it just looks like the speak event isn't being sent.
on another note what is the advantage to using a speech proxy instead of the default speaker client?
Old October 31st, 2014, 05:46 AM
Blade's Avatar
Hopefully someone will capture a debug log of this issue and put in a ticket on my site so I can have a look
As for the speech proxy... it provides a way to intercept all speech and perform pre and post actions on the speech message. Here are some of the things you can do in BLSpeech
  • User can enable or disable Speech Proxy
  • User can specify multiple special processing tags which will be interpreted by the plugin. See the help for details on the tags.
  • Proxy mode allows the user to specify NORMAL mode when they are at home or AWAY mode when they are away from the house. In AWAY mode, all speech is queued (depending on the special processing tags)
  • User can setup an unlimited number of speakers and speaker zones which can be triggered using the special processing tags.
  • User can setup an unlimited number of sound files which can be triggered by using the special processing tags.
  • Phrase Rules can be setup to allow the user to perform an action on any message that contains a certain phrase.
  • User can view the current high priority and normal priority queues.
  • User can specify whether to log all speech activity to a log file and view and clear the log. The number of days to keep the logs can also be specified.
  • User can mute/unmute the speech in HomeSeer.
  • User can choose to show the last X number of speech messages in a device code of their choice.
  • User can setup words in the plug-in dictionary that will allows substitution in their speech messages.
  • HomeSeer event triggers, actions and conditions can be used in the plug-in.
  • The AB8SS device can be used with the plug-in as long as you have the WAF-ABS8SS plug-in installed as well.
  • User can also interface with the BLAB8SS plug-in.
  • Interfaces with BLRussound
Old October 31st, 2014, 09:34 PM
kenrad's Avatar
Blade,
I sent the log to you in an email please take a look and see what you can figure out
Thanks again for your support
Cheers Ken
Old October 31st, 2014, 10:49 PM
kenrad's Avatar
Blade,
Cheers Ken
Old November 1st, 2014, 08:38 PM
kenrad's Avatar
as a test I set up a simple event to just turn on a light when the reminder was triggered but that didn't work either so it seems that the reminder is not being sent at all
Cheers Ken
Old November 1st, 2014, 10:13 PM
sparkman's Avatar
Hi Ken,
I'm seeing this as well now. I've opened a Help Desk ticket on Bob's site and uploaded a debug log.
Cheers
Al
Old November 1st, 2014, 10:16 PM
kenrad's Avatar
I sent bob the logs and im testing a new version right now
Old November 1st, 2014, 10:27 PM
Blade's Avatar
I am not sure what is going on because I just did a test here with the newest build and it announced my reminder just fine
FYI... It will not announce a reminder that is in the past
Old November 1st, 2014, 10:33 PM
sparkman's Avatar
Hi Bob,
I created a few reminders tonight about 30 minutes before the show was to start with an announcement and a script that were supposed to trigger 5 minutes ahead of the start time. The Current Reminders list showed them but the announcement and script never triggered. Looking at my debug file, it looks like it's not iterating through all of the reminders/favorites.
Al
Old November 1st, 2014, 10:38 PM
Blade's Avatar
I have replied to the ticket. Are you not receiving the emails?
Old November 1st, 2014, 10:41 PM
sparkman's Avatar
I hadn't looked at my emails tonight. Took a quick look and I did get them.
Old November 1st, 2014, 10:43 PM
sparkman's Avatar
Downloading 1.0.55.0 now.
Old November 1st, 2014, 11:09 PM
sparkman's Avatar
Hi Bob,
Looks to be working with the new version. I'll upload the debug log as well.
Al
BLTVGuide Blade BLTVGuide 21 September 27th, 2014 05:02 PM
Net CallerID Reads but doesn't speak. KLS WAF NetCallerID (3P) 13 September 1st, 2007 02:21 AM
Speak sometimes doesn't speak zimmer62 HS2 / HSPRO 15 March 30th, 2007 02:47 PM
WAF NetCallerID intermittantly doesn't speak telewizard13 WAF NetCallerID (3P) 0 March 1st, 2007 06:50 PM
Speak Reminders [ASP] Bill Brower Script & Plug-In Library 0 December 7th, 2004 06:24 AM
