I am trying to get Dave to add Russound device detection into his driver so that you could just use the Allonis Russound calls
New changes coming
I see that - I forwarded Dave the log - hopefully a quick fix for that. Are you using HS JSON or did you write your own? I was reviewing the log file and it appears the device type of a switch that controls my shades has the same type as a lighting dimmer (both indicate Z-Wave multilevel switch) -- just curious but I think Dave won't know the difference in the data since to me it looks the same in the log - but, HS knows because a dimmer has different control options in the HS interface... In HS, there is Node Type when I ask for information on the node - wondering is there is an ability to communicate node types - or manufacturer and device - something to tell ML what it is.
Dave did some changes to the homseer plugin and it is much better - my shades are populating as are all my motions/temperature and even Key Fob's! And, the floor level is populated too.
With all this I was wondering if there was a way to have a new feature in your plugin.
It seems you have to check a device in order for it to show in the homeseer plugin - but, checking the device also creates variables and doubles the variables. I believe your plugin maintains the BL device variables and the HS plugin maintains the variables in the Allonis way too (for example, a light becomes light_XXXX and you also maintain BLXXXXX for a single device).
I suggest having 2 checkbox columns for each device - one, to check if the homeseer plugin will use the device, and the other to create variables in Allonis (what you have now) - basically, the ability to just click Homeseer and let that method rule and not have all the BL variables maintained too. So, if I check a device for HS and not BL, then HS plugin does it thing and no BL variables are created or maintained. I find some devices I want to bypass HS (for example, your Russound plugin) whereas others I would bypass your variables (light switches/dimmers).
Otherwise this is really great!
Hi Blade - do we still have an option to go the other way? Execute an Allonis CMD from HS3? I'm still struggling with Russound/GCC across both systems... If I let your Russound plugin takeover, Allonis loses control of it... don't know if it's a hardware contention issue given that my Russound CAV66 is serial port driven through a GCC on the Allonis side. All I am trying to do is enable something as simple as 192.168.1.111/command?AV|4~Power~2~Toggle where the IP address is the Allonis server.
