Calibration problem with Fibaro shutter switch
    Not sure why, but one of my shutter blinds detached itself from the "roller-axle" and consequently, although I have managed to re-attach the shutter, the calibration is out-of-synch.
    I tried the procedure of pressing s1 for >3 secs three times, but the shutter just opens partially and then closes again.
    Any idea how I can re-calibrate the limits correctly?
    Thanks for any tips.......
    By looking at the manual, looks like you might have to press the switch several times before it gets into calibration mode:
    https://manuals.fibaro.com/roller-shutter-2/
    BTW: What type of shutter motor are you using?
    I'm looking for relatively cheap solutions. Live in the northeast and houses around here usually have lots of smaller windows, so it adds up.
      In fact in the end it wasn't a problem at the Fibaro level....the motor limits had got themselves screwed up and needed resetting after the shutter was re-attached to the shaft.
      I'm not sure what make the motors are - I'm in Switzerland and my guess is they are German- had them about 20 years.
