Hi All,
Have been upgrading my system sorting out gremlins all is well and very stable.
Went away for a few days and received an e-mail to say board 1 disconnected, this is normally followed by an e-mail saying board 1 reconnected alas not this time.
On returning home found this in the log.
Arduino Plugin. Warning = Unable to connect to Board 1 Com Port No: 14 does not Exist.
I have two board connected via USB.
Whilst the cure is to disable and re enable the Com Port locally this is not exactly ideal. I would hopefully like to find a fix that can be run when the above log entry occurs.
I am currently running 1.0.0.131 of the the plugin and see that 1.0.0.147 in the beta section may well fix this issue so this for me is the next step.
Just wonder has anybody had issues with this and does it completely disappear with 1.0.0.147?
Some will say change to an ethernet shield, for me this is not an easy option as both my MEGA's are mounted and wired in a project box and there is not room to mount an ethernet shield on either let alone both.
One option I have thought of is to run a script to disable and re enable the com port. Is this possible? No expert here so have no idea!
Peter
Edit Now upgraded to Version 1.0.0.147
Win 7 Home Premium x64
Intel Celeron(R) J1900 @ 1.99 GHz
16 GB RAM
Homeseer HS3 Pro Registered
Devices 349
Events 150
Active Plugins Arduino BLBackup BlGData BLOccupied BLUPS Mediacontroller RXFCOM SCSIP Ultra1Wire WeatherXML X10 Z-Wave
Disabled Plugins BLRadar NetCAM UltraCID3 UltraGCIR3
Peter
16 GB RAM
Devices 349
Events 150
