Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > HomeSeer Wall Dimmers & Switches
HomeSeer Wall Dimmers & Switches Forum for HomeSeer Wall Dimmers & Switches
Old June 14th, 2018, 09:12 PM
Fellhahn's Avatar
Fellhahn Fellhahn is offline
Seer
HS-WD200+ FW 5.11 teaser video.
The HomeSeer YouTube channel has posted a video teasing the 5.11 firmware update for HS-WD200+. The video focuses on the ability to use association group 2 to configure multiple WD200s as companion switches, without the need for a traveller wire.
"Available soon at homeseer.com"
Here's hoping 'soon' really is soon.
- Michael
Old June 15th, 2018, 01:52 AM
Timon's Avatar
Timon Timon is offline
Seer Deluxe
Don't know if it would make a big difference in price price but could you make a version of the WD200, let's call it the WC200 for grins, that leaves out all of the dimming hardware and only has the led status, z-wave interface and paddle switch?
John (N6BER), Joyce, Lucas (Golden Ret mix), Bella (Great Pyrenees) and Lance (GP).
HomeSeer Version: HS3 Standard 3.0.0.435
Linux version: hs3 4.14.34-v7+ #1110 SMP Mon Apr 16 15:18:51 BST 2018 armv7l GNU/Linux
Mono version: 5.12.0.226
Z-NET V2 - Version 1.0.23
Number of Devices: 257
Number of Events: 320
Available Threads: 399
HSTouch Enabled: True
3.0.0.13: AirplaySpeak
3.0.0.48: EasyTrigger
3.0.1.109: PHLocation
0.0.0.42: Pushover 3P
3.0.1.190: Z-Wave
Old June 15th, 2018, 08:59 AM
Fellhahn's Avatar
Seer
I'd love a device like that, seeing as I'm not using the WD200s connected to any load. I buy them for the status LEDs and the 4/5 tap control.
Old June 15th, 2018, 09:56 AM
rprade's Avatar
rprade rprade is offline
OverSeer
Quote:
In all reality, the cost would only be slightly less. It would still need everything the dimmer has except for the actual dimming device, usually a MOSFET. These devices cost less than a buck or from DigiKey and that is retail. At the manufacturing level these devices are likely only a few cents. Everything else that makes a dimmer would still have to be there for for this control device.
Randy Prade
Aurora, CO
Prades.net
Old June 15th, 2018, 10:15 AM
Tomgru Tomgru is online now
Seer Master
that's nice.... but uninterested until I can reliably dim below 20% :-)
HTML code is Off
WD200+ LED Color smacarth HomeSeer Wall Dimmers & Switches 49 June 11th, 2018 11:35 AM
Help with HS-WD200+ jrjmpls7 HomeSeer General Discussion Area 4 June 10th, 2018 12:08 PM
200 Series Video Teaser macromark HomeSeer Wall Dimmers & Switches 10 December 31st, 2017 10:38 AM
HS3 Teaser - Device Status #1 macromark HS3 / HS3PRO Discussion 24 October 21st, 2014 06:59 PM
HS3 Teaser - Events #1 macromark HS3 / HS3PRO Discussion 62 October 15th, 2014 05:03 PM
