tenScriptAid 1.26 with CAPIControlUse Now Available
    Version 1.26 of tenScriptAid is now available, now supporting display of the CAPI ControlUse device definitions.
    Video showing capability and explaining CAPIControlUse here:
    https://youtu.be/1NagAM7SQVI
    tenholde
    tenholde
    Again, Thanks for these great tools.
    Don
      I am trying to download the tenScriptAid for HS3 at http://tenholder.net/tenWare2/tenScr...ptAid_1_26.zip
        Just downloaded from both inside and outside of my LAN.
        Please try again, perhaps with another browser, and let me know.
        tenholde
        tenholde
          Woke up to a Microsoft update, and tenScriptAid not working. I can connect to homeseer but then the tenScriptAid window goes to the toolbox section at the bottom of the screen and can't be maximized. If I run the mouse over the tenScriptAid icon, I can see an image of the main screen but can't maximize it.
          Anyone run into this?
          Don
            Are you running the current version?
            tenholde
              Yes. 1.26
              Don
                Fixed it by deleting the folder it was in, creating a new folder, extracting the zip in that folder, and bingo! All is good.
                Don
                  Let me know if you can reproduce this behavior
                  tenholde
                    Will do.
                    Don
                      Well, I don't know how to suggest a way for you to reproduce this problem, but it recurred when I went to use tenScriptingAid a moment ago.
                      I doubleclick on tenScriptingAid, the not connected window comes up, I click 'connect' and the program minimizes with an icon in the bottom of the screen. When I click the icon, it stays minimized. The following image shows the icon in the tool tray and the mouse over it. Clicking it does nothing.
                      Which I could offer more information.
                      Don
                        Hi Ed;
                        Have a chance to look into this? Hope it's an easy fix as I have gotten use to using this as a great tool for debugging.
                        Where do you install the file that has all the information that populates the app when you first start it? I'd like to delete that and see if that helps.
                        Don
                          Hi Ed;
                          Look in folder something like this:
                          C:\Users\joe\AppData\Local\Microsoft\tenScriptAid.exe_Url_y1 bpp0jnd5ottnlc3u1vohus2cynuwvm\1.26.0.0
                          please send me a copy of the config file
                          tenholde
                          tenholde
                            The problem occurs if you close tenScriptAid when it is minimized.
                            If you delete the config file, it should work again.
                            Until I can issue a fix, do not close the program while it is minimized.
                            tenholde
                            tenholde
                              Here you go. I had about 10 folders from various versions, deleted them all but one. As you suggested, deleting the config file worked.
                              Don
