Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Spud Plug-Ins > Alexa (3P)
Alexa (3P) Spud Alexa plugin that uses the Alexa Voice Service.
Old September 29th, 2015, 01:56 PM
spud's Avatar
spud spud is offline
Moderator
Alexa Plug-in - Beta Testing
This plugin is designed to interface HomeSeer with the Alexa Voice Service. It allows to use Alexa with any microphone and speakers connected to your Windows machine (i.e. a replacement for the Echo device)
Please report any bug.
Please read the User Guide before installing.
Installation:
  • download the zip attached to this post and save it in the HS3 application folder in /updates3/zips
  • download the file named updater_override.txt attached to this post and save it in the HS3 application folder.
  • go to the "PLUG-INS > Manage" page and click the "Update Listing" button, then click "Additional interfaces > Test Plugin" and check the Alexa line.
  • click the "Download and Install" button
  • enable the plugin from the "PLUG-INS > Manage" page
  • delete updater_override.txt from your HS3 application folder
Changes to v3.0.0.1:
- Fixed plugin shutdown
- Display a message error in config page when Microsoft Server Speech Platform Runtime x86 is not installed.
Old September 29th, 2015, 02:26 PM
Rotech's Avatar
Rotech Rotech is offline
Sweet.... Will be playing with it tonight. One question. What would be the attention phrase if you use it with the Kinect device? The one you assigned to Kinect?
Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Old September 29th, 2015, 03:35 PM
spud's Avatar
Moderator
the attention phrase would be the one you assign in the Alexa plugin config page, which by default is "Alexa"
Old September 29th, 2015, 04:25 PM
DJF3's Avatar
DJF3 DJF3 is offline
When browsing to ipaddress/alexaconfig I only see "Error"
sep-29 22:28:14 WARNING The Alexa plugin hasn't been authorized to access the Al
exa Voice Service, please go to the config page to authorize.
sep-29 22:36:46 ERROR Retrieving the COM class factory for component with CLSID
{49428A60-C997-4D0E-9808-9E326C178D58} failed due to the following error: 800401
54 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG
sep-29 22:36:47 ERROR Retrieving the COM class factory for component with CLSID
Any idea what the problem could be?
DJ
...projects, scripts & tips: http://www.domoticaworld.com
Old September 29th, 2015, 04:45 PM
Rotech's Avatar
Installation went very smoothly , responds very good to attention Frace . Now how do you run event within homeseer? Modify the events with A Alexa trigger?
Old September 29th, 2015, 04:46 PM
spud's Avatar
Moderator
DJ
Have you installed the Microsoft Speech Platform as explained in the user guide ?
If so which one have you installed x86 or x64?
Old September 29th, 2015, 05:08 PM
Rotech's Avatar
Spud, how do I run events using Alexa?
Old September 29th, 2015, 05:12 PM
spud's Avatar
Moderator
If you want Alexa to trigger a HS event or to control a HS device, you will need Thrag's echo plugin (http://board.homeseer.com/showthread.php?t=176481) or the official HS Echo App (which has not been released yet)
But since you are already using the Kinect plugin I don't see a good reason why you would want to use Alexa to trigger your events rather than the Kinect plugin?
Old September 29th, 2015, 05:16 PM
Rotech's Avatar
Ok, I thought it was part of the functionality. I can live with that.. One thing I noticed that is doesn't know where it's at. I asked for the time and it gave me a different time???
Old September 29th, 2015, 05:24 PM
Rotech's Avatar
I asked my location she told me I was in Seattle...
Old September 29th, 2015, 05:26 PM
spud's Avatar
Moderator
go there: http://alexa.amazon.com/#settings
click on your device, and then set your zip code
Old September 29th, 2015, 07:18 PM
dcdelong's Avatar
dcdelong dcdelong is offline
Spud,
Can this PI be run remote? In other words leverage the speakers and microphone of the Windows 10 workstation on my office desk?
Chris
HSPRO3 3.0.0.368 on HP 8000, 9 SONOS, Vista p20 alarm, 3 IPads and HP Touch Screen, 22 z-Wave, 54 INSTEON
Plugins :BLBackup:,Pushover 3P:,Wiimote:Winery,HSTV:,Insteon:,PHLocation:,drhsIpPlugIn:, UltraNetatmoWelcome3:,UltraSighthoundVideo3:,Vista Alarm:,UltraCID3:,Random:,EasyTrigger:,iAutomate RFID:,FitbitSeer:,Z-Wave:,HSTouch Server:,weatherXML:,Sonos:,Restart:,UltraGCIR3:,UltraPioneer AVR3:JowiHue;WiiMote;MyQ
Old September 29th, 2015, 08:34 PM
akraymod3 akraymod3 is offline
Can I send the voice to the Sonos plugin?
Old September 29th, 2015, 10:33 PM
spud's Avatar
Moderator
Originally Posted by dcdelong View Post
Spud,
Chris
Yes this is one of the goal. It is supposed to work right now, but I haven''t tested a remote instance so far. I will test and add some instructions to the user guide
Old September 29th, 2015, 10:36 PM
spud's Avatar
Moderator
not right now, but it's a feature I want to investigate, i.e use a homeseer speaker client or a media plugin as the speaker for the Alexa plugin
Old September 30th, 2015, 03:20 AM
DJF3's Avatar
Yes and x64 (on Windows 7)
Old September 30th, 2015, 07:52 AM
spud's Avatar
Moderator
please try to install the x86 version even if you are on a 64bits system.
thanks
Old September 30th, 2015, 12:12 PM
Pete's Avatar
Pete Pete is offline
@Spud,
I would like to give your Alexa plugin a try with my HS3 setup which is a bit unique.
Main mothership HS3 is running in Ubuntu 14.04 64 bit. I have a VB of Windows server 32 bit running on the same box.
I am running HS3 stuff right now on the Wintel server which talks to the mothership running in Ubuntu.
Downloaded zip.
Will try first just running it remotely eh?
Automator
HS3 Pro & Lite Edition Beta 3.0.0.4449
Old September 30th, 2015, 03:33 PM
spud's Avatar
Moderator
Here are some instructions to run the plugin remotely:
First you need to install it on your HS machine (but you don't have to enable it) so that HS doesn't complain about licensing issue when you start your remote instances.
Then
  • copy HSPI_Alexa.exe, and all the dlls in bin/Alexa to a directory on your remote computer
  • copy the folder Data/Alexa from your HS3 directory to the same remote directory and keep the same directory tree (i.e Data/Alexa)
  • copy HomeSeerAPI.dll, HSCF.dll and Scheduler.dll from your HS3 directory to the same remote directory
  • install the microsoft speech platform and runtime language on your remote computer as explained in the user guide.
  • open a command prompt on your remote computer
  • cd to the directory, then type HSPI_Alexa.exe server=<ip_of_your_hs_machine> instance=<instance_name>
where <instance_name> can be anything you want but only alpha numeric characters
Old September 30th, 2015, 03:37 PM
spud's Avatar
Moderator
Originally Posted by Pete View Post
@Spud,
Downloaded zip.
Pete, follow the instructions above, except that to be able to install the plugin on your Ubuntu machine using the updater, you need to edit updater_override.txt and change the 4th parameter on the Alexa line from 31 to 63.
Tags
alexa, alexa voice service, echo, voice recognition
Nest Plug-in - Beta Testing spud Nest Devices (3P) 176 April 30th, 2018 10:37 AM
UPB Plug-in - Beta Testing spud UPB plugin by Spud (3P) 102 December 30th, 2017 11:57 PM
HS3 Beta Plug-In Available for Testing YoYo IRTrans (3P) 92 November 6th, 2017 09:10 PM
Wiimote plug-in - Beta Testing spud WIIMote Plugin (3P) 22 June 17th, 2015 07:13 PM
Bitcoin Plug in - Beta Testing spud Bitcoin Plugin (3P) 1 October 25th, 2014 07:48 AM
