Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > CFGuy Plug-Ins/Scripts > WeatherXML
WeatherXML Discussion area for WeatherXML
Old May 12th, 2016, 01:44 PM
herbus herbus is offline
Seer Plus
Precipitation in % and mm
For my sprinklers I want to use the data from WeatherXML. To deside if the sprinklers should be active I want to make an analysis of the precipitation of today and the forecasted precipitation for the next 3 days.
I found the HST settings that provide devices with the precipitation forecast in %. But is it possible to also have devices with the precipitation in mm?
I use Wunderground and on their site the precipitation forecast is like: 50 % / 2 mm
Thanks in advance!
Herbus (Jo)
Old May 14th, 2016, 11:48 AM
CFGuy's Avatar
CFGuy CFGuy is offline
Have A Blessed Day
I checked the download data and the rain in mm and inches is available.
I will add it to my list of things to do.
Jeff Farmer
HS 3.0.0.312, HSPhone
Other Plugins In Use: APCUPSD, EasyTrigger, FBitSeer, HSTouch Server, Kinect, PHLocation, Pushover, RFXCom, UltraGCIR3, UltraMon3, UltraPioneerAVR3, X10, Z-Wave
Hardware: GoControl Irrigation Controler, Schlage Lever Lock, Schlage Deadbolt, Way2Call Hi-Phone, RFXCom RFXrec433 Receiver, WGL 800, TI-103, Z-Net, Pioneer 1120, Pioneer 1021, Panasonic BDT-110, Panasonic BDT-210 x2
Old May 15th, 2016, 04:39 AM
Seer Plus
That would be great. Thanks!
Old August 5th, 2016, 06:23 PM
CFGuy's Avatar
Have A Blessed Day
I am starting to work on the bug list and will be working of feature requests later this month. Yours is on my list.
Old August 5th, 2016, 06:45 PM
cheeryfool's Avatar
cheeryfool cheeryfool is offline
Super Seer
Jeff. That's very similar to why I put my request in. I am going to play around with my own algorithm using the data from the PWS that's less than a quarter mile from me. I may also setup my own PWS at sometime.
cheeryfool
Old June 14th, 2018, 09:37 PM
shill shill is offline
I'm assuming "Rain Today" and "Rain Past Hour" were added as a result of this. How about adding "QPF All Day" in the forecast devices section? In addition to knowing whether I want to run the sprinklers based on today's rain amount, it would be good to know how much is anticipated for tomorrow as well...
Old June 15th, 2018, 03:23 PM
CFGuy's Avatar
Have A Blessed Day
I replied in another thread and should have waited until I checked the actual code.
The rain totals in the forecast are using the qdf for the Forecast Daytime Precipitation Inches, Forecast Nighttime Precipitation Inches, and Forecast Total Precipitation Inches
Old June 16th, 2018, 09:17 AM
Sorry if I'm being dense, but how do I get to the value for "Forecast Total Precipitation Inches"? That's not a device and I don't see a global variable for it, so I assume I'm missing something.
Old June 16th, 2018, 09:56 AM
CFGuy's Avatar
Have A Blessed Day
Go to the page labeled HSTouch. These are the devices that are designed for HS3. The ones on the page labeled Devices are legacy ones left over from HS2.
On the HSTouch page, if you are using Weather Underground, you should see a section labeled Precipitation Device Items. There is also a section labeled Precipitation Historical.
The Precipitation Device Items is where you select which days you want the forecast for.
The Precipitation Historical is where you can go up to 7 days of past data.
You can setup devices to show the total for each day and there is also devices for an accumulative total. On those Day 4 would be the total of Day 1, 2 3 and 4.
Old June 17th, 2018, 01:47 PM
Aha! I don't use HSTouch that much so I never bothered looking at that tab.
Can you clarify the way the cumulative totals are updated? Is today's rainfall included or do I need to add the two together?
In other words, if I check at 6AM to see how much it's rained in the last 3 days, will the fact that's rained 2 inches since midnight be in the Day 3 historical data or do I need to add the Current Rain device? I'm thinking they need to be added together based on your description above.
Old June 17th, 2018, 02:21 PM
CFGuy's Avatar
Have A Blessed Day
You are correct. It would not have the current day included in the total.
Old June 19th, 2018, 09:34 AM
The historical/accumulated rainfall devices don't seem to be working correctly. On Monday 6/18, we received .8 inches of rain, which was properly reflected in "Rain Today" in current conditions.
However, I now see Accumulation Day 1, Day 2, and Day 3 with a value of "0.15", and the amount shown for the historical Precipitation Amount Day 1 is also "0.15".
What happened to my 0.8 inches?
Old June 19th, 2018, 11:33 AM
CFGuy's Avatar
Have A Blessed Day
If you would, on the schedules page, set the conditions to keep 72 backups. That would cover 3 days of once an hour updates.
If you have it saving some backups already, check the xml file for what the value was in the last file before midnight last night.
I need to refresh myself on the code so I don't give you an incorrect answer now. I get off at 4PM central and will take a look at the code then.
Old June 19th, 2018, 11:39 AM
Thanks. Turned those on just now, so I don't have any data for this particular instance of the problem. But since I was actively working on my formula for "how long do I need to run the sprinklers based on the target amount for a 3 day window - the amount in the last 3 days - the amount already today - the amount forecast for today/tomorrow (adjust by likelihood)", I paid close attention to the data the last couple of days.
The good news is my formula is working. The bad news is it thinks I need to run the sprinklers today because we didn't accumulate much rain the last 3 days...
Let me know what else you need - I've also turned on Device History for the "Rain Today" device (unfortunately switching from "Devices" to "HSTouch" for my current conditions also wiped out my tracking of the history) so I'll have that to compare as well next time.
Old June 19th, 2018, 08:39 PM
CFGuy's Avatar
Have A Blessed Day
I'm not seeing anything that jumps out and says this is where the error is.
At Midnight, I create a temp array and set the 0 value to the value from current rain today variable. It would be the total from the last download and import from the (at that point) previous day. The value stored in currentRainToday is used for both of the device types. I then load the array 1 to 7 with the values from the past 7 days.
The value are then moved up one. array(7) gets set to array(6), etc.
After the individual days are set, it then adds days together to get the accumulated values.
Day 1 = temp array 0.
Day 5 = Day 0 + Day 1 ... + Day 4
I have 2 sets of totals. One for the value for each day and one for the values of the accumulated totals.
After all the values are set, I loop over the devices and update them.
We got .83 inches today and have had no rain in the past 6 days. I'll check my totals in the morning and keep an eye on them by checking the backup xml files compared to the totals showing in the devices.
Old June 20th, 2018, 09:17 AM
Seems pretty straightforward - I wonder if it has something to do with the fact that it was newly created and didn't have data? Perhaps a variable that doesn't get reset if the values aren't there?
I'm trying to figure out how it's possible to have this situation:
And of course I have no idea what happened to the .8 inches from a couple of days ago (where this now says ".15"), but not sure we'll ever get to the bottom of that one!
Old June 21st, 2018, 09:02 AM
CFGuy's Avatar
Have A Blessed Day
I had .83 inches of rain on Tuesday.
My totals are in the image below.
If your totals don't start being correct, I'll add some debugging to get some more detailed info of what is happening.
HTML code is On
Trying to read precipitation forecast Walt Boudreaux WeatherXML 2 April 28th, 2013 03:25 PM
precipitation rate and nozzle notes bunkers mcsSprinklers 1 July 15th, 2008 08:07 PM
