Trying to install a new Aeon multi-monitor, I unplugged my Z-stick. This on on the old Zee, not the S2.
After I paired the monitor & the z stick, I am getting repeated "The Z-Stick 2x interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning" after I put the z stick back into the Zee. I have removed power to the Zee and rebooted multiple times and always the same thing.
The new multi-monitor flashes if the Zee is off when the I power up the monitor, but it stops flashing as soon as the Zee & z stick reboot, so I feel like the pairing worked & the z stick isn't dead. Also, the z stick flashes if I press the button and then quits flashing if I press it again.
Is there anything to do but replace the z stick? I've got enough devices that rebuilding the network would take quite a while.
