Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > iTunes DAAP (3P)
iTunes DAAP (3P) iTunes third party plugin for HS3 that supports iTunes control using the DAAP protocol.
Old March 20th, 2017, 04:29 PM
alonhes alonhes is offline
Viewer
Can't connect to itunes - pairing problem
I have HomeTroller Zee S2
Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
ERROR Object synchronization method was called from an unsynchronized block of code.
And then
DEBUG at Mono.Zeroconf.Providers.AvahiDBus.RegisterService.RegisterDB us () <0x71f967a8 + 0x002a3> in :0 at Mono.Zeroconf.Providers.AvahiDBus.RegisterService.Register () <0x71f96540 + 0x00017> in :0 at Mono.Zeroconf.RegisterService.Register () <0x71f96508 + 0x0002b> in :0 at HSPI_ITUNES_DAAP.PairingServer.PublishService () <0x71f95450 + 0x0024b> in :0 at HSPI_ITUNES_DAAP.PairingServer.Start () <0x71f91460 + 0x0012b> in :0 at HSPI_ITUNES_DAAP.WebConfig.postBackProc (System.String page, System.String data, System.String user, System.Int32 userRights) <0x71f8f818 + 0x00263> in :0
Can you please help? I installed the avahi as you wrote in the tutorial
Old March 24th, 2017, 04:52 PM
Viewer
Managed to solve the issue. In case anyone else have same problem.
You should copy Mono.Zeroconf.Providers.Avahi.dll to iTunesDAAP installation folder (in my case it's under /usr/local/HomeSeer/bin/iTunesDAAP/)
I took this file from Airplay Speak plugin (same location under AirplaySpeak)
Old March 25th, 2017, 08:23 AM
spud's Avatar
spud spud is offline
Moderator
I have fixed this issue in version 3.0.0.29 available here.
Now all the needed dlls should be installed with the plug-in.
Unable to Connect to iTunes with Zee S2 warrenmr iTunes DAAP (3P) 8 March 30th, 2017 01:58 AM
iTunes Connection Problem mhulse iTunes DAAP (3P) 5 January 19th, 2014 01:39 PM
iTunes filter problem? tblackmon9599 Apple iTunes 2 January 27th, 2013 02:44 AM
Problem with iTunes saraza Apple iTunes 1 November 11th, 2010 10:58 PM
Problem with iTunes plugin Rien du Pre Apple iTunes 20 October 3rd, 2009 12:19 PM
